- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: Bruno Barras <bruno.barras AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Navigation commands forbidden in files
- Date: Wed, 13 Jun 2012 11:40:57 -0400
> You could use modules:
> Module Attempt1.
> End Attempt1.
> Module Attempt2.
> End Attempt2.
> ... (* now the preferred style *)
> That should provide more or less the same semantics as Reset, but in a more
> structured way. Moreover, that lets you refer to older attempts from the
> preferred style.
It does not provide exactly the same semantics as Reset, if one is
inside a section right ?
Section t.
Variable toto : tutu.
Definition tata : ...
Reset tata.
End t.
has to be translated in
Module Attempt1.
Section t.
End t.
End Attempt1.
Module Attempt2.
Section t.
End t.
End Attempt2.
which may require to copy paste a lot of context.
- [Coq-Club] Navigation commands forbidden in files, Adam Chlipala, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Pierre Casteran, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Bruno Barras, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Adam Chlipala, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Ramana Kumar, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Thomas Braibant, 06/13/2012
