- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Navigation commands forbidden in files
- Date: Wed, 13 Jun 2012 17:30:22 +0200
You could use modules:
Module Attempt1.
End Attempt1.
Module Attempt2.
End Attempt2.
... (* now the preferred style *)
That should provide more or less the same semantics as Reset, but in a more structured way. Moreover, that lets you refer to older attempts from the preferred style.
Bruno.
On 06/13/2012 05:17 PM, Pierre Casteran wrote:
Yes, I met the same problem while writing tutorials or material for
Lectures.
This pattern is useful for comparing various styles of definition.
Pierre
Quoting Adam Chlipala
<adamc AT csail.mit.edu>:
This is the new error message that Coq 8.4beta2 gives when using coqc to process files that use commands like [Reset]. Unfortunately, I've been relying on such commands in CPDT <http://adam.chlipala.net/cpdt/>, for didactic typesetting of command sequences that would never be present in polished source files in "real" projects. For instance, I will introduce a bad definition, work through examples showing why it is bad, and then [Reset] and redefine it.
Does anyone have suggestions on how to refactor to support 8.4beta2?
Bruno Barras Typical team - INRIA Saclay
LIX - Ecole Polytechnique 91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57 Fax: +33 1 69 33 30 14
- [Coq-Club] Navigation commands forbidden in files, Adam Chlipala, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Pierre Casteran, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Bruno Barras, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Adam Chlipala, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Ramana Kumar, 06/13/2012
- Re: [Coq-Club] Navigation commands forbidden in files, Thomas Braibant, 06/13/2012
