Re: [Coq-Club] Conditioning notations on whether something is in [Prop] or in a larger [Type].
- To: Bas Spitters <spitters AT cs.ru.nl>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Conditioning notations on whether something is in [Prop] or in a larger [Type].
- Date: Wed, 29 Aug 2012 04:35:33 -0400
Thanks. That doesn't seem to be the complete story, though, because rewriting and [reflexivity]/[symmetry]/[transitivity] all just work for something like
Set Implicit Arguments.
Inductive identity_dep (A : Type) (a : A) : forall B : Type, B -> Type :=
identity_dep_refl : identity_dep a a.
Anyway, I'll keep you updated. So far, I've managed to implement versions of [reflexivity], [symmetry], and [transitivity] that allow relations in [Type] rather than [Prop] without much trouble. I'm currently exploring rewriting (which I don't yet understand well enough to implement), mostly by trying to replace [Prop] with [Type] in Coq.Relations.Relation_Definitions, Coq.Classes.RelationClasses, and Coq.Classes.Morphisms. I've ~finished the first two (though I haven't quite finished the versions that permit relations to be both [A -> A -> Type] and [A -> A -> Prop], depending on whether [A : Type] or [A : Prop]), and I'm about 2/3 of the way though Coq.Classes.Morphisms (universe inconsistency errors keep giving me trouble. So far, I've bypassed all of them by some combination of replacing [Definition]s with [Notation]s, expanding out definitions manually, and duplicating a [Fixpoint].)
-Jason
On Wed, Aug 29, 2012 at 4:09 AM, Bas Spitters <spitters AT cs.ru.nl> wrote:
The patch is here:
https://sympa.inria.fr/sympa/arc/coq-club/2011-05/msg00204.html
Your work should also be useful for homotopy type theory, so please
keep us informed about your progress.
Best,
Bas
On Wed, Aug 29, 2012 at 10:02 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
> Thanks! Is this done mostly in ocaml? (grepping the source tree suggests
> yes.) Is it replicable in pure Coq?
> Are there plans to generalize this feature a la [Add Parametric Relation]
> and [Add Parametric Morphism]?
> -Jason
> On Wed, Aug 29, 2012 at 3:24 AM, Bas Spitters <spitters AT cs.ru.nl> wrote:
>> On Wed, Aug 29, 2012 at 7:45 AM, Jason Gross <jasongross9 AT gmail.com>
>> wrote:
>> > I'm trying to generalize some of the standard library constructs to
>> > permit
>> > the use of [Type] rather than [Prop] (in particular, the structures that
>> > are
>> > behind the scenes of [reflexivity], [transitivity], [symmetry], [Add
>> > Parametric Relation], [Add Parametric Morphism], and
>> > [rewrite]/[setoid_rewrite]).
>> Some of these issues have been resolved when using [identity] instead of
>> [eq].
>> Bas
- [Coq-Club] Conditioning notations on whether something is in [Prop] or in a larger [Type]., Jason Gross, 08/29/2012
- Re: [Coq-Club] Conditioning notations on whether something is in [Prop] or in a larger [Type]., Bas Spitters, 08/29/2012
- Re: [Coq-Club] Conditioning notations on whether something is in [Prop] or in a larger [Type]., Jason Gross, 08/29/2012
- Re: [Coq-Club] Conditioning notations on whether something is in [Prop] or in a larger [Type]., Robbert Krebbers, 08/29/2012
