- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: S3 <scubed2 AT gmail.com>
- Cc: AUGER Cédric <sedrikov AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: refine skipping hole
- Date: Mon, 8 Oct 2012 21:40:53 +0200
There is no way to ask for this sort of things in Coq v8.3. Simply put, the (internal) representation of proofs in progress does not allow to express that. After a serious re-engineering, Coq v8.4 has a command Grab Existential Variables, which brings every such hole as a goal. I also have a branch where refine directly exposes all the unsolved holes, but it still gives surprising (albeit correct) results when the hole is in a pattern-matching branch (if you want to play with it, you can find the branch on github: https://github.com/aspiwack/coq (branch new-tacticals) ).
On 7 October 2012 03:00, S3 <scubed2 AT gmail.com> wrote:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
>> To learn about accessibility and well-foundedness, I tried to prove that
>> the Ackermann function is well-founded. I'm using "Coq 8.3pl1 (July
>> 2011)". (Yes, I know that I can just write it using 2 fixes.)
>> I wrote the program at the bottom of this message. However, when I go to
>> prove the ack_step function (in the comment at the bottom), I leave 2
>> holes. However, refine only adds the 2nd as an obligation, skipping the
>> first. How do I manually add an Existential as an Obligation? I tried
>> many variations of Focus Existential 1. Focus ?45. etc. but none of them
>> allow me to go to it. Why is it skipped? How do I Focus on it?
>> (* Ackermann function.
>> Attempt showing well-foundedness with the Ackermann function, even though
>> nest recursion handles it directly.
>> I am having a problem with refine skipping a hole. How do I go to the
>> hole explicitly? *)
>> Definition ack_ord (p q : nat*nat) := let (a1, b1) := p in let (a2, b2)
>> := q in a1 < a2 \/ (a1 = a2 /\ b1 < b2) .
>> Theorem le_Sn_0 n: S n <= 0 -> False. intros. inversion H. Qed.
>> Theorem le_S_both a b: a <= b -> S a <= S b. intros. induction H. apply
>> le_n.
>> apply le_S. apply IHle. Qed.
>> Theorem le_0 a: 0 <= a. induction a. apply le_n.
>> apply le_S. apply IHa. Qed.
>> Theorem ack_wf_b: forall a, Acc ack_ord (a, 0) -> forall b, Acc ack_ord
>> (a, b). intros. induction b. apply H.
>> apply Acc_intro. induction y. intros. induction H0. apply (Acc_inv IHb).
>> apply or_introl. apply H0.
>> induction H0. rewrite H0. clear H0 a0. inversion H1. apply IHb.
>> apply IHb. apply or_intror. apply conj. apply eq_refl.
>> apply H2. Qed.
>> Theorem ack_wf: well_founded ack_ord. unfold well_founded. induction a.
>> apply ack_wf_b. clear b. induction a. apply Acc_intro. induction y.
>> intros. induction H. apply le_Sn_0 in H. apply (False_ind _ H).
>> induction H. apply le_Sn_0 in H0. apply (False_ind _ H0).
>> apply Acc_intro. induction y. intros. apply ack_wf_b. induction H.
>> inversion H. apply IHa.
>> apply (Acc_inv IHa). apply or_introl. apply H1.
>> induction H. apply le_Sn_0 in H0. apply (False_ind _ H0). Qed.
>> (* Theorem ack_step x (f : forall y, ack_ord y x -> nat) : nat. refine (
>> match x as z return x = z -> nat with | pair a b => fun H => match a as c
>> return a = c -> nat with | 0 => fun _ => S b | S a0 => fun H2 => f ( a0,
>> match b as d return b = d -> nat with | 0 => fun _ => 1 | S b0 => fun H3
>> => f (a, b0) _ end (eq_refl b) ) _ end (eq_refl a) end (eq_refl x) ).
>> (* Skips first hole for f (a, b0) _ *)
>> (* 2nd hole *)
>> rewrite H. rewrite H2. apply or_introl. apply le_n.
>> (* Can't save, how do I go back to first Existential hole? *)
>> No more subgoals but non-instantiated existential variables: Existential
>> 1 = ?56 : [x : nat * nat f : forall y : nat * nat, ack_ord y x -> nat a :
>> nat b : nat a0 := a : nat b0 := b : nat H : x = (a, b) a1 : nat a2 := a1
>> : nat H2 : a0 = S a1 b1 : nat b2 := b1 : nat H3 : b0 = S b1 |- ack_ord
>> (a0, b2) x]
> I am not sure if the following solution is an acceptable answer. In
> general, you can use the "instantiate" tactic to fill an existential. But
> in doing so, you have to provide a full term.
> Theorem ack_step x (f : forall y, ack_ord y x -> nat) : nat. refine ( match> a = c -> nat with | 0 => fun _ => S b | S a0 => fun H2 => let g := fun b0
> x as z return x = z -> nat with | pair a b => fun H => match a as c return
> H3 => _ in f ( a0, match b as d return b = d -> nat with | 0 => fun _ => 1
> | S b0 => fun H3 => f (a, b0) (g b0 H3) end (eq_refl b) ) _ end (eq_refl
> a) end (eq_refl x) ).> (* Skips first hole for f (a, b0) _ *) subst. right; repeat constructor.
>Yes, I saw in the documentation about giving explicit
> (* 2nd hole *)
> subst. apply or_introl. apply le_n.
terms for Existentials. I wanted to use the interactive
theorem prover to fill in the gaps.
The trick of using a separate function and allowing
me to fill it in that way works. Thanks!
I'm still a bit curious if there's a way to tell
it that I want to interactively edit the hole.
But, my immediate problem is solved with that workaround.
iEYEARECAAYFAlBw1DQACgkQxzVgPqtIcfs5hACeJnlUjQ/6mk6K+MV/SFAWHilC
$_="sccc,gB1,a_oo,JosBackuSa,g11,ug1a,oscc,cBBg,JcgaBuucaB_s11_Juc_c";
while(($c,$b,$a)=m/^(.)([^,]*),(.*)$/){$_=$a;s/$c/$b/g;}
print map chr length,split /_/;
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
C30An3ntHP3go62WUfYPfRReOKNf14UE
=15cm
-----END PGP SIGNATURE-----
- [Coq-Club] refine skipping hole, S3, 10/06/2012
- Re: [Coq-Club] refine skipping hole, AUGER Cédric, 10/06/2012
- [Coq-Club] Re: refine skipping hole, S3, 10/07/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/08/2012
- Re: [Coq-Club] Re: refine skipping hole, S3, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, AUGER Cédric, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Pierre Courtieu, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Enrico Tassi, 10/09/2012
