coq-club - Re: [Coq-Club] simplifying functions defined with dependent pattern matching
  • To: dan portin <danportin AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] simplifying functions defined with dependent pattern matching
  • Date: Tue, 9 Oct 2012 14:20:17 +0200
Le Tue, 9 Oct 2012 02:25:46 -0700,
dan portin
a écrit :
> In order to understand how to write functions with dependent pattern
> matching, I decided to write a library of dependently typed AVL trees
> mirroring the implementation of AVL trees in the Agda standard
> library. The binary search tree property is enforced as usual, by
> encoding lower and upper bounds on tree elements as type parameters.
> The balancing property for AVL trees is encoded by indexing the trees
> by their height, and ensuring that the absolute value of the
> difference between the heights never exceeds one via the constructors
> for Bal. Here is an example with the type of the tree elements
> (parameterized over a computable linear order with setoid equality)
> specialized to naturals, so as to be relatively brief:
> Require Import Unicode.Utf8.
> Require Import Utf8_core.
> Require Import Arith.
> Inductive Bal : nat → nat → Set :=
> | E : ∀ {h : nat}, Bal h h
> | P : ∀ {h : nat}, Bal h (S h)
> | N : ∀ {h : nat}, Bal (S h) h.
> Definition maxB {n m : nat} (φ : Bal n m) : nat :=
> match φ with
> | E h => h
> | P h => S h
> | N h => S h
> end.
> Inductive T (ρ₁ ρ₂ : nat) : nat → Type :=
> | Leaf : ρ₁ < ρ₂ → T ρ₁ ρ₂ 0
> | Node : ∀ {h₁ h₂} (φ : Bal h₁ h₂) (x : nat), T ρ₁ x h₁ → T x ρ₂
> h₂ → T ρ₁ ρ₂ (S (maxB φ)).
> Arguments Leaf [ρ₁ ρ₂] H.
> Arguments Node [ρ₁ ρ₂ h₁ h₂] φ x l r.
> One of the functions necessary for defining insert joins two AVL
> trees and one element, where the height of the first AVL tree may
> violate the balancing invariant by one. This is encoded using a
> dependent pair of an element of a two-element type along with an AVL
> tree. I have used bool for the two-element type, although it would
> probably be better to define a custom datatype for bits:
> Definition succB (i : bool) (n : nat) :=
> match i with
> | true => S n
> | false => n
> end.
> Definition joinL₁ {ρ₁ ρ₂ h₁ h₂} (φ₁ : Bal h₁ h₂) (x₁ : nat)
> (σ : {i : bool & T ρ₁ x₁ (succB i h₁)}) (t₂ : T x₁ ρ₂ h₂) :
> {i : bool & T ρ₁ ρ₂ (succB i (S (maxB φ₁)))} := ...
> There are several lemmas necessary to write joinL₁, so I will list
> them and then the definition of joinL₁ essentially translated from
> Agda. The definition of the latter may not be the prettiest, and uses
> the "convoy pattern" trick from Chlipala's book in order to generate
> elements of my data structure with the correct types. I could
> probably afford to generate some abstractions that would improve
> readability. See the Agda stlib for a specification:
> Definition injS {x y : nat} : S x = S y → x = y :=
> λ H : S x = S y, f_equal pred H.
> Definition unjS {x y : nat} : x = y → S x = S y :=
> λ H : x = y, f_equal S H.
> Definition caseS (n : nat) (A : Type) : Type :=
> nat_rect (λ x, Type) unit (λ x y, A) n.
> Notation "'rewL' E 'in' H" := (eq_rect _ _ H _ E) (at level 10, H at
> level 10).
> Notation "'rewR' E 'in' H" := (eq_rect_r _ H E) (at level 10, H at
> level 10).
> Lemma balS {n m : nat} : Bal n m → Bal (S n) (S m).
> Proof. destruct 1; constructor. Defined.
> Lemma maxR {n m : nat} (φ : Bal n m) : Bal (maxB φ) n.
> Proof. destruct φ; constructor. Defined.
> Lemma maxL {n m : nat} (φ : Bal n m) : Bal m (maxB φ).
> Lemma maxS {n m : nat} (φ : Bal n m) : Bal (maxB (maxR φ)) (maxB
> (maxL φ)). Proof. destruct φ; constructor. Defined.
> Lemma maxB_lemma {n m : nat} (φ : Bal n m) : S (maxB (balS (maxS φ)))
> = S (S (maxB φ)).
> Proof. destruct φ; reflexivity. Defined.
> Lemma succtrue {n : nat} : succB true n = S n.
> Proof. auto. Defined.
> Lemma succfalse {n : nat} : succB false n = n.
> match (projT1 σ) as i₁ return
> T ρ₁ x₁ (succB i₁ h₁) → {i : bool & T ρ₁ ρ₂ (succB i (S (maxB
> φ₁)))} with | false => λ (t₁ : T ρ₁ x₁ (succB false h₁)),
> existT (λ i : bool, T ρ₁ ρ₂ (succB i (S (maxB φ₁)))) false
> (Node φ₁ x₁ t₁ t₂)
> | true => λ (t₁ : T ρ₁ x₁ (succB true h₁)),
> match φ₁ as φ₁ in Bal h₁ h₂ return
> T ρ₁ x₁ (succB true h₁) → T x₁ ρ₂ h₂ →
> {i : bool & T ρ₁ ρ₂ (succB i (S (maxB φ₁)))} with
> | E η₁ => λ (t₁ : T ρ₁ x₁ (succB true η₁)) (t₂ : T x₁ ρ₂ η₁),
> existT (λ i : bool, T ρ₁ ρ₂ (succB i (S (maxB E)))) true
> (Node N x₁ t₁ t₂)
> | P η₁ => λ (t₁ : T ρ₁ x₁ (succB true η₁)) (t₂ : T x₁ ρ₂ (S
> η₁)), existT (λ i : bool, T ρ₁ ρ₂ (succB i (S (maxB P)))) false (Node
> E x₁ t₁ t₂)
> | N η₁ => λ (t₁ : T ρ₁ x₁ (succB true (S η₁))) (t₂ : T x₁ ρ₂
> η₁), match t₁ in T _ _ η return
> η = succB true (S η₁) → caseS η {i : bool & T ρ₁ ρ₂ (succB
> i (S (maxB N)))} with
> | Leaf _ => λ (E₁ : O = succB true (S η₁)), tt
> | Node h₃ h₄ φ₂ x₂ t₃ t₄ => λ (E₁ : S (maxB φ₂) = succB
> true (S η₁)),
> match φ₂ as φ₂ in Bal h₃ h₄ return
> T ρ₁ x₂ h₃ → T x₂ x₁ h₄ → maxB φ₂ = S η₁ →
> {i : bool & T ρ₁ ρ₂ (succB i (S (maxB N)))} with
> | E η₂ => λ (t₃ : T ρ₁ x₂ η₂) (t₄ : T x₂ x₁ η₂) (E₂ :
> maxB E = S η₁),
> let τ₁ := Node N x₁ (rewL E₂ in t₄) t₂ in
> existT (λ i : bool, T ρ₁ ρ₂ (succB i (S (maxB N))))
> true (Node P x₂ (rewL E₂ in t₃) τ₁)
> | N η₂ => λ (t₃ : T ρ₁ x₂ (S η₂)) (t₄ : T x₂ x₁ η₂)
> (E₂ : maxB N = S η₁),
> let τ₁ := Node E x₁ (rewL (injS E₂) in t₄) t₂ in
> false (Node E x₂ (rewL E₂ in t₃) τ₁)
> | P η₂ => λ (t₃ : T ρ₁ x₂ η₂) (t₄ : T x₂ x₁ (S η₂))
> (E₂ : maxB P = S η₁),
> match t₄ in T _ _ η return
> η = S η₂ → caseS η {i : bool & T ρ₁ ρ₂ (succB i (S
> (maxB N)))} with
> | Leaf _ => λ E₃ : 0 = S η₂, tt
> | Node h₅ h₆ φ₃ x₃ t₅ t₆ => λ E₃ : S (maxB φ₃) =
> S η₂, let τ₁ := Node (maxR φ₃) x₂ (rewR (injS E₃) in t₃)
> t₅ in
> let τ₂ := Node (maxL φ₃) x₁ t₆ (rewR (injS
> (rewL E₂ in E₃)) in t₂) in
> let τ₃ := rewL (maxB_lemma φ₃) in Node (balS
> (maxS φ₃)) x₃ τ₁ τ₂ in
> let τ₄ := rewR succfalse in (rewL (unjS (rewL
> E₂ in E₃)) in τ₃) in
> N)))) false τ₄
> end eq_refl
> end t₃ t₄ (injS E₁)
> end eq_refl
> end t₁ t₂
> end (projT2 σ).
> I am having the following problem. Consider the membership function
> over AVL trees and the following lemma, which states that joinL₁
> preserves tree membership. This is necessary in order to prove that,
> for instance, the insertion function behaves correctly with respect
> to set membership for a library of finite sets:
> Fixpoint mem {ρ₁ ρ₂ h} (x : nat) (t : T ρ₁ ρ₂ h) : Prop :=
> match t with
> | Leaf H => False
> | Node h₁ h₂ φ y l r =>
> match lt_eq_lt_dec x y with
> | inleft (right EQ) => True
> | inleft (left LT) => mem x l
> | inright GT => mem x r
> end
> end.
> Definition mem_joinL₁ {ρ₁ ρ₂ h₁ h₂} (φ₁ : Bal h₁ h₂) (x₁ : nat)
> ∀ y : nat, mem y (projT2 (joinL₁ φ₁ x₁ σ t₂)) ↔
> mem y (projT2 σ) ∨ mem y t₂ ∨ x₁ = y.
> Proof.
> destruct σ as [i₁ t₁].
> destruct i₁.
> destruct φ₁.
> admit.
> admit.
> dependent destruction t₁.
> dependent destruction φ.
> admit.
> admit.
> admit.
> admit.
> Qed.
> With the knowledge that lt is irreflexive and asymmetric, along with
> some simple tactics, it's trivial to prove the first two and last
> holes in the proof of mem_joinL₁. The problem comes in the third,
> fourth, and fifth holes. What happens is that Coq refuses to simplify
> joinL₁ because dependent destruction is not destructing t₁ correctly.
> For instance,
> ρ₁ : nat
> ρ₂ : nat
> h : nat
> x₁ : nat
> h0 : nat
> x0 : nat
> t₁1 : T ρ₁ x0 h0
> t₁2 : T x0 x₁ h0
> t₁0 : T ρ₁ x₁ (succB true (S h))
> x1 : maxB E = S h
> x : Node E x0 t₁1 t₁2 ~= t₁0
> t₂ : T x₁ ρ₂ h
> ∀ y : nat,
> mem y
> (projT2
> (joinL₁ N x₁ (existT (λ i : bool, T ρ₁ x₁ (succB i (S h)))
> true t₁0) t₂))
> ↔ mem y (projT2 (existT (λ i : bool, T ρ₁ x₁ (succB i (S h))) true
> t₁0)) ∨ mem y t₂ ∨ x₁ = y
> The second instance of existT _ true t₁0 simplifies as expected, but
> the first instance does not. I assume that the problem has to do with
> a conflict between the types that joinL₁ and the dependent pair
> expect. However, I cannot figure out how to rewrite using x1 and x in
> combination with generalizations of variables, pattern, and so forth,
> in order to generate a term which will simplify appropriately. The
> solution that I am working on is to write the proof term by hand,
> using elimination predicates in order to generate terms with the
> correct types. This doesn't seem like the best solution. Is there one?
I would suggest you to put the depth as a parameter instead of an
indice in your T type.
(You can try to redefine my joinL₁ without tactics, you just have to do
a Print joinL₁, copy paste the output, indent, add lacking anotations,
remove useless ones)
match φ with
| E h => h
| P h => S h
| N h => S h
end.
Inductive T (ρ₁ ρ₂ h : nat) : Type :=
| Leaf : h = 0 → ρ₁ < ρ₂ → T ρ₁ ρ₂ h
h = S (maxB φ) → T ρ₁ x h₁ → T x ρ₂ h₂ →
T ρ₁ ρ₂ h.
Arguments Leaf [ρ₁ ρ₂] h Heq H.
Arguments Node [ρ₁ ρ₂] h [h₁ h₂] φ x Heq l r.
match i with
| true => S n
| false => n
end.
level 10).
level 10).
Lemma maxS {n m : nat} (φ : Bal n m) : Bal (maxB (maxR φ)) (maxB (maxL
Lemma maxB_lemma {n m : nat} (φ : Bal n m) : maxB (balS (maxS φ)) = S
(maxB φ). Proof. destruct φ; reflexivity. Defined.
{i : bool & T ρ₁ ρ₂ (succB i (S (maxB φ₁)))}.
generalize (projT2 σ).
destruct (projT1 σ); simpl; clear σ.
destruct φ₁.
exists true.
right with (S h) h N x₁; auto.
exists false.
right with (S h) (S h) E x₁; auto.
intros [Heq H|h₁ h₂ φ₂ x₂ Heq l r].
refine (match Heq with eq_refl => I end).
generalize (injS Heq); clear Heq.
destruct φ₂; simpl in *; intros.
exists true.
simpl in *.
right with h0 (S h0) P x₂; simpl; auto.
right with (S h) h N x₁; simpl; auto.
revert r; destruct H; auto.
destruct r.
generalize I.
refine (match e with eq_refl => I end).
exists false.
right with _ _ (balS (maxS φ)) x; simpl; auto.
revert e H.
destruct (maxB_lemma φ).
intros [].
intros [].
split.
right with _ _ (maxR φ) x₂; simpl; auto.
case (injS e); auto.
right with _ _ (maxL φ) x₁; simpl; auto.
case (injS H); auto.
exists false.
right with (S h0) (S h0) E x₂; simpl; auto.
right with h h E x₁; simpl; auto.
revert r.
generalize (injS H).
intros []; auto.
exists false; simpl.
right with h₁ h₂ φ₁ x₁; auto.
Defined.
match t with
| Leaf _ H => False
| Node h₁ h₂ φ y H l r =>
end
end.
Proof.
destruct i₁.
destruct φ₁.
