- To: dan portin <danportin AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] simplifying functions defined with dependent pattern matching
- Date: Tue, 09 Oct 2012 08:55:51 -0400
On 10/09/2012 05:25 AM, dan portin wrote: ρ₁ : nat
The second instance of existT _ true t₁0 simplifies as expected, but
the first instance does not. I assume that the problem has to do with a
conflict between the types that joinL₁ and the dependent pair expect.
However, I cannot figure out how to rewrite using x1 and x in
combination with generalizations of variables, pattern, and so forth,
in order to generate a term which will simplify appropriately. The
solution that I am working on is to write the proof term by hand, using
elimination predicates in order to generate terms with the correct
types. This doesn't seem like the best solution. Is there one?ρ₂ : nat h : nat x₁ : nat h0 : nat x0 : nat t₁1 : T ρ₁ x0 h0 t₁2 : T x0 x₁ h0 t₁0 : T ρ₁ x₁ (succB true (S h)) x1 : maxB E = S h x : Node E x0 t₁1 t₁2 ~= t₁0 t₂ : T x₁ ρ₂ h ============================ ∀ y : nat, mem y (projT2 (joinL₁ N x₁ (existT (λ i : bool, T ρ₁ x₁ (succB i (S h))) true t₁0) t₂)) ↔ mem y (projT2 (existT (λ i : bool, T ρ₁ x₁ (succB i (S h))) true t₁0)) ∨ mem y t₂ ∨ x₁ = y You're closer than you think! This is at all takes to get similar simplification to previous cases: simpl in *; subst; rewrite <- x; simpl. What happens is that the [simpl in *] reduces [x1] so that it has only a variable on its lefthand side, at which point [subst] easily rewrites the goal so that all the tricky dependent type issues are gone. |
- [Coq-Club] simplifying functions defined with dependent pattern matching, dan portin, 10/09/2012
- Re: [Coq-Club] simplifying functions defined with dependent pattern matching, AUGER Cédric, 10/09/2012
- Re: [Coq-Club] simplifying functions defined with dependent pattern matching, Adam Chlipala, 10/09/2012
