- To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- Cc: Pierre Courtieu <pierre.courtieu AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: refine skipping hole
- Date: Tue, 9 Oct 2012 14:23:22 +0200
Le Tue, 9 Oct 2012 12:01:00 +0200,
Arnaud Spiwack
a écrit :
> > Mmmh I would say it does have something to do with side effects
> > since (still in v8.4) when you go back and forth in a script the
> > existential variables numbers actually change. Is there any reason
> > for that by the way?
> None. It's just simpler this way (for now). It's true that it makes
> the naming of existential variables worse, but it's not like you can
> control those that exist in the background, so side effect or not, as
> long as the names are generated, they will look bad.
> Arnaud
Of course they looks bad, but avoiding this side effect could help in
understanding mechanics. If existentials change each time you
undo/redo, it is hard to figure who was who. For teaching purpouse, it
is good to have some deterministic generation name also.
- [Coq-Club] refine skipping hole, S3, 10/06/2012
- Re: [Coq-Club] refine skipping hole, AUGER Cédric, 10/06/2012
- [Coq-Club] Re: refine skipping hole, S3, 10/07/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/08/2012
- Re: [Coq-Club] Re: refine skipping hole, S3, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Arnaud Spiwack, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, AUGER Cédric, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Pierre Courtieu, 10/09/2012
- Re: [Coq-Club] Re: refine skipping hole, Enrico Tassi, 10/09/2012
