coq-club - [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?
  • Date: Wed, 10 Oct 2012 20:29:23 -0400
On Wed, Oct 10, 2012 at 8:18 PM, Catalin Hritcu
<catalin.hritcu AT gmail.com>
wrote:
> I've run into some inconsistent behavior with Coq 8.4, in which hints
> in "core" are ignored by eauto, but the same hints added to a
> different hint database or directly with the "using" clause work just
> fine. I've attached a small bit of a larger development where this
> problem was quite pervasive. Here are the most interesting bits:
> (* This works *)
> Lemma red1_t : exists t', red1 tt t'.
> Proof.
> eauto using red1.
> Qed.
> (* This also works *)
> Lemma red1_t'' : exists t', red1 tt t'.
> Proof.
> eauto using red1_beta.
> Qed.
> Create HintDb mydb.
> Hint Constructors red1 : mydb.
> Lemma red1_t' : exists t', red1 tt t'.
> Proof.
> eauto with mydb.
> Qed.
> (* But this doesn't work! *)
> Hint Constructors red1.
> Lemma red1_t''' : exists t', red1 tt t'.
> Proof.
> eauto.
> Abort.
> (* Unfolding tt makes it work though *)
> Proof.
> unfold tt. debug eauto.
> Qed.
> (* But not with Hint Unfold? *)
> Hint Unfold tt.
> Lemma red1_t'''' : exists t', red1 tt t'.
> Proof.
> debug eauto.
> Abort.
> (* Still no luck *)
> Lemma red1_t''''' : exists t', red1 tt t'.
> Proof.
> debug eauto with core.
> Abort.
Was myself confused about this very last test. I forgot that mydb
contained other hints already.
> (* But if we use a database that's not core it all works *)
> Hint Unfold tt : mydb.
> Proof.
> debug eauto with mydb.
> Qed.
If we start with a fresh hint database we actually see that Hint
Unfold doesn't help even in this last case.
Create HintDb mydb_fresh.
Hint Unfold tt : mydb_fresh.
Proof.
debug eauto with mydb_fresh.
Abort.
Anyway, the first tests show that eauto is not as smart about
unfolding for "core" as it is for other hint databases.
Cheers,
Catalin
