Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?
- To: Catalin Hritcu <catalin.hritcu AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?
- Date: Wed, 10 Oct 2012 20:46:01 -0400
[Hint Unfold] does not go into a database used by [eauto]. You probably want [Hint Extern 0 => unfold tt]. I imagine that [core] has a lot of other lemmas that are getting in the way of this particular lemma.
-Jason
On Wed, Oct 10, 2012 at 8:29 PM, Catalin Hritcu <catalin.hritcu AT gmail.com> wrote:
Was myself confused about this very last test. I forgot that mydbOn Wed, Oct 10, 2012 at 8:18 PM, Catalin Hritcu
> I've run into some inconsistent behavior with Coq 8.4, in which hints
> in "core" are ignored by eauto, but the same hints added to a
> different hint database or directly with the "using" clause work just
> fine. I've attached a small bit of a larger development where this
> problem was quite pervasive. Here are the most interesting bits:
> (* This works *)
> Lemma red1_t : exists t', red1 tt t'.
> Proof.
> eauto using red1.
> Qed.
> (* This also works *)
> Lemma red1_t'' : exists t', red1 tt t'.
> Proof.
> eauto using red1_beta.
> Qed.
> Create HintDb mydb.
> Hint Constructors red1 : mydb.
> Lemma red1_t' : exists t', red1 tt t'.
> Proof.
> eauto with mydb.
> Qed.
> (* But this doesn't work! *)
> Hint Constructors red1.
> Lemma red1_t''' : exists t', red1 tt t'.
> Proof.
> eauto.
> Abort.
> (* Unfolding tt makes it work though *)
> Proof.
> unfold tt. debug eauto.
> Qed.
> (* But not with Hint Unfold? *)
> Hint Unfold tt.
> Lemma red1_t'''' : exists t', red1 tt t'.
> Proof.
> debug eauto.
> Abort.
> (* Still no luck *)
> Lemma red1_t''''' : exists t', red1 tt t'.
> Proof.
> debug eauto with core.
> Abort.
contained other hints already.
If we start with a fresh hint database we actually see that Hint
> (* But if we use a database that's not core it all works *)
> Hint Unfold tt : mydb.
> Proof.
> debug eauto with mydb.
> Qed.
Unfold doesn't help even in this last case.
Create HintDb mydb_fresh.
Hint Unfold tt : mydb_fresh.
Lemma red1_t'''' : exists t', red1 tt t'.debug eauto with mydb_fresh.
Proof.
Abort.
Anyway, the first tests show that eauto is not as smart about
unfolding for "core" as it is for other hint databases.
Cheers,
Catalin
- [Coq-Club] Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/11/2012
- [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/11/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Jason Gross, 10/11/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/11/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Tom Prince, 10/14/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/14/2012
- Re: [Coq-Club] Why does eauto treat "core" differently than the other hint databases?, Matthieu Sozeau, 10/14/2012
