Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?
- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?
- Date: Sat, 13 Oct 2012 20:55:49 -0400
On Sat, Oct 13, 2012 at 7:37 PM, Tom Prince
wrote:
> Catalin Hritcu
> <catalin.hritcu AT gmail.com>
> writes:
>> OK, I've simplified the test illustrating the problem even further:
> There are a number of properties of databases that affect how they get
> used, besides just hints. 'Print HintDb <name>.' might give some useful
> information on what exactly is going on.
Thanks Tom, this is indeed very useful for diagnosing the problem.
Print HintDb shows indeed big differences between "core" and newly
created hint databases.
Print HintDb core.
(* Non-discriminated database
Unfoldable variable definitions: none
Unfoldable constant definitions: none
Create HintDb mydb.
Print HintDb mydb.
Unfoldable variable definitions: all
Unfoldable constant definitions: all
This also shows that Jason's trick works:
Hint Transparent one.
Print HintDb core.
Unfoldable constant definitions: one
The main remaining questions: (1) why are the defaults for "core" set
this way and (2) is there any way to change them?
Thanks,
Catalin
- [Coq-Club] Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/11/2012
- [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/11/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Jason Gross, 10/11/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/11/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Tom Prince, 10/14/2012
- Re: [Coq-Club] Re: Why does eauto treat "core" differently than the other hint databases?, Catalin Hritcu, 10/14/2012
- Re: [Coq-Club] Why does eauto treat "core" differently than the other hint databases?, Matthieu Sozeau, 10/14/2012
