- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq's kernel reduction mechanism
- Date: Wed, 17 Oct 2012 17:34:31 +0200
Hello Chantal,
Chapter 3 of Bruno Barras' thesis should be a good match ;) You can download it from his homepage, although it seems unreachable at the moment.
Roughly speaking, the conversion test is implemented by interleaved reduction steps and term comparisons (as opposed to the VM which goes straight to normal form). The reduction is performed by a call by need abstract machine.
Hope it helps.
Maxime.
On 17/10/2012 17:28, Chantal Keller wrote:
Dear Coq club,
I am looking for information about the "standard" Coq's kernel reduction
mechanism. By this, I mean the mechanism involved in the conversion rule
when doing "Qed." (in usual proofs, ie. when the VM is not called). Can
you give me a pointer on its working?
Thanks,
- [Coq-Club] Coq's kernel reduction mechanism, Chantal Keller, 10/17/2012
- Re: [Coq-Club] Coq's kernel reduction mechanism, Maxime Dénès, 10/17/2012
- Re: [Coq-Club] Coq's kernel reduction mechanism, Chantal Keller, 10/18/2012
