- To: Kevin Sullivan <sullivan.kevinj AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] An interated composition puzzle
- Date: Sat, 10 Nov 2012 09:22:11 -0500
On 11/10/2012 08:54 AM, Kevin Sullivan wrote:
My students presented two solutions to the simple problem of applying a
function f n times to an argument x (iterated composition). The first says
apply f to the result of applying f n-1 times to x; the second, apply f n-1
times to the result of applying f to x. I challenged one student to prove that
the programs are equivalent. This ought to be pretty easy based on the
associativity of composition. Your best solution?
Fixpoint ant {X: Type} (f: X->X) (x: X) (n: nat) : X :=
match n with
| O => x
| S n' => f (ant f x n')
end.
Fixpoint ant' {X: Type} (f: X->X) (x: X) (n: nat) : X :=
match n with
| O => x
| S n' => ant' f (f x) n'
end.
Theorem equiv: forall (X: Type) (f: X->X) (x: X) (n: nat),
(ant f x n) = (ant' f x n).
Proof. admit.
Here's a pretty short solution:
Section ant.
Variable X : Type.
Variable f : X -> X.
Fixpoint ant (n : nat) (x : X) : X :=
match n with
| O => x
| S n' => f (ant n' x)
end.
Fixpoint ant' (n : nat) (x : X) : X :=
match n with
| O => x
| S n' => ant' n' (f x)
end.
Ltac t := simpl; intuition (try autorewrite with core; auto).
Hint Extern 1 (_ = _) => progress f_equal.
Lemma ant'_fwd : forall n x,
ant' n (f x) = f (ant' n x).
induction n; t.
Qed.
Hint Rewrite ant'_fwd.
Theorem equiv: forall n x,
ant n x = ant' n x.
induction n; t.
Qed.
End ant.
- [Coq-Club] An interated composition puzzle, Kevin Sullivan, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Adam Chlipala, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Laurent Théry, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, AUGER Cédric, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Jean-Francois Monin, 11/11/2012
- Re: [Coq-Club] An interated composition puzzle, Jonas Oberhauser, 11/11/2012
- Re: [Coq-Club] An interated composition puzzle, AUGER Cédric, 11/11/2012
