- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: Jean-Francois Monin <jean-francois.monin AT imag.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] An interated composition puzzle
- Date: Sun, 11 Nov 2012 21:21:52 +0100
Am 11.11.2012 20:36, schrieb AUGER Cédric:
Le Sun, 11 Nov 2012 20:00:25 +0100,
Jonas Oberhauser
<s9joober AT gmail.com>
a écrit :
Is this really stronger? I do not have 8.4 installed but I believeYour belief is wrong.
this compiles (in 8.4):
Lemma equalsto : (forall (X: Type) (f: X->X) n, (fun x => ant f x n)
= (fun x => ant' f x n))
= (forall (X: Type) (f: X->X) (n: nat) (x: X), (ant f x n) = (ant'
f x n)).
reflexivity. Qed.
∀ X (f:X→X) n, (λ x, ant f x n) = (λ x, ant' f x n)
and
∀ X (f:X→X) n x, ant f x n = ant' f x n
are not unifiable (or so do I hope).
Ahhh I misread. No wonder was I confused. I agree that they are not convertible : ) I thought all that happened was an eta expansion (which looked weird to me), but this time we prove that the procedures are the same, not just the outcomes. I can see how that is a stronger result.
Coq doesn't allow me to rewrite beneath the quantifiers when I needYes and no.
the quantified variables :( Is there a way around this?
More precisely, in the proofs, I had something like:
H:(λ x, F x n) = (λ x, G x n)
and needed to prove
(λ x, F (f x) n) = (λ x, f (G x n))
what I did was a:
change (λ x, F (f x) n) with (λ x, (λ x, F x n) (f x)).
Then I could do
rewrite H.
I see...
Do you think this should be provable:
Lemma simpleexample X f g : (forall x : X, f x = g x) -> (forall x : X, f x = x) = (forall x : X, g x = x).
Obviously I can prove that the two propositions are equivalent, but I want to prove that they are equal. If equality means convertibility, I certainly think this is true.
Kind regards, Jonas
Am 11.11.2012 17:28, schrieb Jean-Francois Monin:
Additional exercise: prove the following stronger version
Theorem identical : forall (X: Type) (f: X->X) n,
(fun x => ant f x n) = (fun x => ant' f x n).
This can be done without axiom (in Coq 8.4).
Warning: there is a funny trick to use somewhere, so to speak.
The above statement is somewhat weird. It is better to consider:
Theorem identical2 : forall (X: Type) (f: X->X) n,
ant2' f n = ant2 f n.
with obvious definitions for ant2 and ant2' such that
ant2 f n = fun x => ant f x n
ant2' f n = fun x => ant' f x n
JF
On Sat, Nov 10, 2012 at 02:54:57PM +0100, Kevin Sullivan wrote:
My students presented two solutions to the simple problem of
applying a function f n times to an argument x (iterated
composition). The first says apply f to the result of applying f
n-1 times to x; the second, apply f n-1 times to the result of
applying f to x. I challenged one student to prove that the
programs are equivalent. This ought to be pretty easy based on the
associativity of composition. Your best solution?
Fixpoint ant {X: Type} (f: X->X) (x: X) (n: nat) : X :=
match n with
| O => x
| S n' => f (ant f x n')
end.
Fixpoint ant' {X: Type} (f: X->X) (x: X) (n: nat) : X :=
match n with
| O => x
| S n' => ant' f (f x) n'
end.
Theorem equiv: forall (X: Type) (f: X->X) (x: X) (n: nat),
(ant f x n) = (ant' f x n).
Proof. admit.
- [Coq-Club] An interated composition puzzle, Kevin Sullivan, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Adam Chlipala, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Laurent Théry, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, AUGER Cédric, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Jean-Francois Monin, 11/11/2012
- Re: [Coq-Club] An interated composition puzzle, Jonas Oberhauser, 11/11/2012
- Re: [Coq-Club] An interated composition puzzle, AUGER Cédric, 11/11/2012
