- To: Jean-Francois Monin <jean-francois.monin AT imag.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] An interated composition puzzle
- Date: Sun, 11 Nov 2012 20:00:25 +0100
Is this really stronger? I do not have 8.4 installed but I believe this compiles (in 8.4):
Lemma equalsto : (forall (X: Type) (f: X->X) n, (fun x => ant f x n) = (fun x => ant' f x n))
= (forall (X: Type) (f: X->X) (n: nat) (x: X), (ant f x n) = (ant' f x n)).
reflexivity. Qed.
In 8.3, I don't seem to be able to prove "equalsto" even if I assume this:
Axiom eta : forall X Y (f : X -> Y), f = (fun x => f x).
Coq doesn't allow me to rewrite beneath the quantifiers when I need the quantified variables :( Is there a way around this?
Am 11.11.2012 17:28, schrieb Jean-Francois Monin:
Additional exercise: prove the following stronger version
Theorem identical : forall (X: Type) (f: X->X) n,
(fun x => ant f x n) = (fun x => ant' f x n).
This can be done without axiom (in Coq 8.4).
Warning: there is a funny trick to use somewhere, so to speak.
The above statement is somewhat weird. It is better to consider:
Theorem identical2 : forall (X: Type) (f: X->X) n,
ant2' f n = ant2 f n.
with obvious definitions for ant2 and ant2' such that
ant2 f n = fun x => ant f x n
ant2' f n = fun x => ant' f x n
JF
On Sat, Nov 10, 2012 at 02:54:57PM +0100, Kevin Sullivan wrote:
My students presented two solutions to the simple problem of applying a
function f n times to an argument x (iterated composition). The first says
apply f to the result of applying f n-1 times to x; the second, apply f n-1
times to the result of applying f to x. I challenged one student to prove that
the programs are equivalent. This ought to be pretty easy based on the
associativity of composition. Your best solution?
Fixpoint ant {X: Type} (f: X->X) (x: X) (n: nat) : X :=
match n with
| O => x
| S n' => f (ant f x n')
end.
Fixpoint ant' {X: Type} (f: X->X) (x: X) (n: nat) : X :=
match n with
| O => x
| S n' => ant' f (f x) n'
end.
Theorem equiv: forall (X: Type) (f: X->X) (x: X) (n: nat),
(ant f x n) = (ant' f x n).
Proof. admit.
- [Coq-Club] An interated composition puzzle, Kevin Sullivan, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Adam Chlipala, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Laurent Théry, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, AUGER Cédric, 11/10/2012
- Re: [Coq-Club] An interated composition puzzle, Jean-Francois Monin, 11/11/2012
- Re: [Coq-Club] An interated composition puzzle, Jonas Oberhauser, 11/11/2012
- Re: [Coq-Club] An interated composition puzzle, AUGER Cédric, 11/11/2012
