- To: coq-club AT inria.fr
- Subject: [Coq-Club] Seemingly identical type with type error
- Date: Sat, 17 Nov 2012 16:20:25 -0800
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Definition poly_out x :=
match x return match x with | O => unit | _ => nat end with
| O => tt
| S _ => 0
end
Definition poly_in i (x : match i with | 0 => unit | _ => nat end) :=
match i as j return (match j with | 0 => unit | _ => nat end -> nat) with
| 0 => fun u =>
match u with
| tt => 0
end
| _ => fun n =>
match n with
| 0 => 1
| _ => 2
end
end x
Compute (fun j => poly_in j (poly_out j)).
The term "poly_out j" has type "match j with
| 0 => unit
| S _ => nat
end" while it is expected to have type
"match j with
| 0 => unit
| S _ => nat
end".
Is there a way to write that expression to make it type check?
What is it unhappy about?
I also found that Coq (8.3pl1) doesn't want to infer the value
for i in poly_in, so leaving it implicit doesn't work.
I realize that normally I would just declare a new tagged union type,
which would handle the tag i parameter automatically, but I wanted
to see what happens if I go this way.
..*.....**..***.*.........*.*...*..**..**game*.....*........|
*....*..**..*.*.*.*..*.**.*..*..*..**..**of**......**.***...|
*.**.*..**..*.*.**.**..**.**.****..***life.**.****..*.****..|
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlCoKckACgkQxzVgPqtIcfsX5QCfYP3vdjrJvCFg+X51ardCgc4I
6PIAniT9tPcSiczmHWjhjnzlyyMX1lbS
=LZz5
-----END PGP SIGNATURE-----
- [Coq-Club] Seemingly identical type with type error, S3, 11/18/2012
- Re: [Coq-Club] Seemingly identical type with type error, Hugo Herbelin, 11/18/2012
- Re: [Coq-Club] Seemingly identical type with type error, S3, 11/18/2012
