coq-club - Re: [Coq-Club] Seemingly identical type with type error
  • To: S3 <scubed2 AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Seemingly identical type with type error
  • Date: Sun, 18 Nov 2012 02:51:59 +0100
Hi,
Activating display of implicit and low-level information ("Set
Printing All" or Alt-A in menu Display of CoqIDE, or correspondingly
in ProofGeneral) gives the answer:
The type of poly_out is
match j return Type with
| 0 => unit
| S _ => nat
end
while poly_in expects
match j return Set with
| 0 => unit
| S _ => nat
end
You may write explicitly "match x return Set with | O => unit | _ => nat end"
in poly_out, so as to circumvent the solution found by the type
inference mechanism algorithm.
Inference of "i" in poly_in seems to work for me in (at least) 8.3pl2.
Hugo Herbelin
On Sat, Nov 17, 2012 at 04:20:25PM -0800, S3 wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Definition poly_out x :=
> match x return match x with | O => unit | _ => nat end with
> | O => tt
> | S _ => 0
> end
> Definition poly_in i (x : match i with | 0 => unit | _ => nat end) :=
> match i as j return (match j with | 0 => unit | _ => nat end -> nat) with
> | 0 => fun u =>
> match u with
> | tt => 0
> end
> | _ => fun n =>
> match n with
> | 0 => 1
> | _ => 2
> end
> end x
> Compute (fun j => poly_in j (poly_out j)).
> The term "poly_out j" has type "match j with
> | 0 => unit
> | S _ => nat
> end" while it is expected to have type
> "match j with
> | 0 => unit
> | S _ => nat
> end".
> Is there a way to write that expression to make it type check?
> What is it unhappy about?
> I also found that Coq (8.3pl1) doesn't want to infer the value
> for i in poly_in, so leaving it implicit doesn't work.
> I realize that normally I would just declare a new tagged union type,
> which would handle the tag i parameter automatically, but I wanted
> to see what happens if I go this way.
> ..*.....**..***.*.........*.*...*..**..**game*.....*........|
> *....*..**..*.*.*.*..*.**.*..*..*..**..**of**......**.***...|
> *.**.*..**..*.*.**.**..**.**.****..***life.**.****..*.****..|
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2.0.17 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlCoKckACgkQxzVgPqtIcfsX5QCfYP3vdjrJvCFg+X51ardCgc4I
> 6PIAniT9tPcSiczmHWjhjnzlyyMX1lbS
> =LZz5
> -----END PGP SIGNATURE-----
