coq-club - Re: [Coq-Club] Seemingly identical type with type error
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Seemingly identical type with type error
  • Date: Sat, 17 Nov 2012 18:37:04 -0800
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> Hi,
> Activating display of implicit and low-level information ("Set Printing
> All" or Alt-A in menu Display of CoqIDE, or correspondingly in
> ProofGeneral) gives the answer:
> The type of poly_out is
> match j return Type with | 0 => unit | S _ => nat end
> while poly_in expects
> match j return Set with | 0 => unit | S _ => nat end
> You may write explicitly "match x return Set with | O => unit | _ => nat
> end" in poly_out, so as to circumvent the solution found by the type
> inference mechanism algorithm.
Ah, that makes sense. Specifying Set makes it work properly.
Thanks!
Compute (fun j => poly_in j (poly_out j)) 3.
= 1
> Inference of "i" in poly_in seems to work for me in (at least) 8.3pl2.
I meant that while I can do
Compute poly_in 0 tt.
= 0
I can't do
Compute poly_in _ tt.
Error: The term "tt" has type "unit" while it is expected to have type
"match ?22 with
| 0 => unit
| S _ => nat
end".
or even
Compute poly_in _ (tt : match 0 return Set with | 0 => unit | S _ => nat end).
Error: The term "tt:match 0 with
| 0 => unit
| S _ => nat
end" has type "match 0 with
| 0 => unit
| S _ => nat
end" while it is expected to have type
"match ?25 with
| 0 => unit
| S _ => nat
end".
> Hugo Herbelin
> On Sat, Nov 17, 2012 at 04:20:25PM -0800, S3 wrote:
> ********* *BEGIN ENCRYPTED or SIGNED PART* *********
>> Definition poly_out x := match x return match x with | O => unit | _ =>
>> nat end with | O => tt | S _ => 0 end .
>> Definition poly_in i (x : match i with | 0 => unit | _ => nat end) :=
>> match i as j return (match j with | 0 => unit | _ => nat end -> nat)
>> with | 0 => fun u => match u with | tt => 0 end | _ => fun n => match n
>> with | 0 => 1 | _ => 2 end end x .
>> (* Compute (fun j => poly_in j (poly_out j)).
>> The term "poly_out j" has type "match j with | 0 => unit | S _ => nat
>> end" while it is expected to have type "match j with | 0 => unit | S _ =>
>> nat end".
>> Is there a way to write that expression to make it type check? What is it
>> unhappy about?
>> I also found that Coq (8.3pl1) doesn't want to infer the value for i in
>> poly_in, so leaving it implicit doesn't work.
>> I realize that normally I would just declare a new tagged union type,
>> which would handle the tag i parameter automatically, but I wanted to see
>> what happens if I go this way. *)
..*.....**..***.*.........*.*...*..**..**game*.....*........|
*....*..**..*.*.*.*..*.**.*..*..*..**..**of**......**.***...|
*.**.*..**..*.*.**.**..**.**.****..***life.**.****..*.****..|
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlCoSdAACgkQxzVgPqtIcfvcDQCfUsDy7KwI0hvwYq+qTk3eL+VG
YOwAn26ak38+eGyNSYGqlZ5pO2rXOHXL
=kt+S
-----END PGP SIGNATURE-----
