coq-club - [Coq-Club] Problem with setoid rewriting and reduction
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Problem with setoid rewriting and reduction
  • Date: Fri, 23 Nov 2012 09:54:35 +0000
  • Accept-language: en-GB, en-US
Hello
I’ve encountered a problem with setoid rewriting where the search for the relation doesn’t succeed “up to” some simple reductions. I’m not sure if this is expected behaviour, but it’s certainly a bit frustrating. Here’s my example, boiled down to something small.
Inductive Tm (env: nat) : nat -> Type :=
  C : forall t, Tm env t.
Definition globEnv := 5.
Definition tmEq (env: nat) (t: nat) (M1 M2: Tm (env + globEnv) t) :=
  match M1, M2 with C _, C _ => True end.
Global Instance ctxtEq_Reflexive (env t: nat) :
  @Reflexive (@Tm _ _) (@tmEq env t).
Proof. intros x. destruct x. simpl. auto. Qed.
(* This works fine *)
Lemma REFLTEST (t: nat) (M: Tm (0+globEnv) t) : (@tmEq 0 t M M).
Proof. setoid_reflexivity. Qed.
(* This fails with
Error: Tactic failure: The relation tmEq is not a declared reflexive relation.
Maybe you need to require the Setoid library.
Lemma REFLTEST2 (t: nat) (M: Tm globEnv t) : (@tmEq 0 t M M).
In essence, I have a “strongly-typed syntax”, with terms parameterized on an environment and a type, here, for simplicity, just nats. Then I define a relation “tmEq”, add an instance of Reflexive, and attempt to prove a trivial equivalence using setoid_reflexivity. But note the nat-computation inside the definition of tmEq. I would expect both REFLTEST and REFLTEST2 to succeed, as they differ only by a simple reduction, but REFLTEST2 fails.
Any ideas or pointers for help would be much appreciated. Although I have a workaround (the first lemma), I spent a long time tracking it down and I suspect the same thing might happen again in another context. I’m using Coq 8.3.
Cheers
Andrew.
