coq-club - Re: [Coq-Club] Problem with setoid rewriting and reduction
  • From: Thomas Braibant <thomas.braibant AT gmail.com>
  • To: Andrew Kennedy <akenn AT microsoft.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Problem with setoid rewriting and reduction
  • Date: Fri, 23 Nov 2012 11:13:16 +0100
Your particular example works well using Coq 8.4. I do not know the
deep reason for that change, though.
Thomas
On Fri, Nov 23, 2012 at 10:54 AM, Andrew Kennedy
wrote:
> Hello
> I’ve encountered a problem with setoid rewriting where the search for the
> relation doesn’t succeed “up to” some simple reductions. I’m not sure if
> this is expected behaviour, but it’s certainly a bit frustrating. Here’s my
> example, boiled down to something small.
> Inductive Tm (env: nat) : nat -> Type :=
> C : forall t, Tm env t.
> Definition globEnv := 5.
> Definition tmEq (env: nat) (t: nat) (M1 M2: Tm (env + globEnv) t) :=
> match M1, M2 with C _, C _ => True end.
> Global Instance ctxtEq_Reflexive (env t: nat) :
> @Reflexive (@Tm _ _) (@tmEq env t).
> Proof. intros x. destruct x. simpl. auto. Qed.
> (* This works fine *)
> Lemma REFLTEST (t: nat) (M: Tm (0+globEnv) t) : (@tmEq 0 t M M).
> Proof. setoid_reflexivity. Qed.
> (* This fails with
> Error: Tactic failure: The relation tmEq is not a declared reflexive
> relation.
> Maybe you need to require the Setoid library.
> Lemma REFLTEST2 (t: nat) (M: Tm globEnv t) : (@tmEq 0 t M M).
> In essence, I have a “strongly-typed syntax”, with terms parameterized on an
> environment and a type, here, for simplicity, just nats. Then I define a
> relation “tmEq”, add an instance of Reflexive, and attempt to prove a
> trivial equivalence using setoid_reflexivity. But note the nat-computation
> inside the definition of tmEq. I would expect both REFLTEST and REFLTEST2 to
> succeed, as they differ only by a simple reduction, but REFLTEST2 fails.
> Any ideas or pointers for help would be much appreciated. Although I have a
> workaround (the first lemma), I spent a long time tracking it down and I
> suspect the same thing might happen again in another context. I’m using Coq
> 8.3.
> Cheers
> Andrew.
