- To: Thomas Braibant <thomas.braibant AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Problem with setoid rewriting and reduction
- Date: Fri, 23 Nov 2012 10:25:10 +0000
- Accept-language: en-GB, en-US
OK, thanks, I've just installed coq 8.4 side-by-side. I have other problems
with it (Program Definition looping on some examples, I'm told that this
is fixed in trunk, also proof general not working properly on the - + *
markers
from ssreflect) so I had reverted to coq 8.3. Now I'm not sure which way to
turn...
Cheers
Andrew.
-----Original Message-----
[mailto:thomas.braibant AT gmail.com]
Sent: 23 November 2012 10:13
To: Andrew Kennedy
Cc: coq-club
Subject: Re: [Coq-Club] Problem with setoid rewriting and reduction
Your particular example works well using Coq 8.4. I do not know the deep
reason for that change, though.
Thomas
On Fri, Nov 23, 2012 at 10:54 AM, Andrew Kennedy
<akenn AT microsoft.com>
wrote:
> Hello
> I've encountered a problem with setoid rewriting where the search for
> the relation doesn't succeed "up to" some simple reductions. I'm not
> sure if this is expected behaviour, but it's certainly a bit
> frustrating. Here's my example, boiled down to something small.
> Inductive Tm (env: nat) : nat -> Type :=
> C : forall t, Tm env t.
> Definition globEnv := 5.
> Definition tmEq (env: nat) (t: nat) (M1 M2: Tm (env + globEnv) t) :=
> match M1, M2 with C _, C _ => True end.
> Global Instance ctxtEq_Reflexive (env t: nat) :
> @Reflexive (@Tm _ _) (@tmEq env t).
> Proof. intros x. destruct x. simpl. auto. Qed.
> (* This works fine *)
> Lemma REFLTEST (t: nat) (M: Tm (0+globEnv) t) : (@tmEq 0 t M M).
> Proof. setoid_reflexivity. Qed.
> (* This fails with
> Error: Tactic failure: The relation tmEq is not a declared reflexive
> relation.
> Maybe you need to require the Setoid library.
> Lemma REFLTEST2 (t: nat) (M: Tm globEnv t) : (@tmEq 0 t M M).
> In essence, I have a "strongly-typed syntax", with terms parameterized
> on an environment and a type, here, for simplicity, just nats. Then I
> define a relation "tmEq", add an instance of Reflexive, and attempt to
> prove a trivial equivalence using setoid_reflexivity. But note the
> nat-computation inside the definition of tmEq. I would expect both
> REFLTEST and REFLTEST2 to succeed, as they differ only by a simple
> reduction, but REFLTEST2 fails.
> Any ideas or pointers for help would be much appreciated. Although I
> have a workaround (the first lemma), I spent a long time tracking it
> down and I suspect the same thing might happen again in another
> context. I'm using Coq 8.3.
> Cheers
> Andrew.
- [Coq-Club] Problem with setoid rewriting and reduction, Andrew Kennedy, 11/23/2012
- Re: [Coq-Club] Problem with setoid rewriting and reduction, Thomas Braibant, 11/23/2012
- RE: [Coq-Club] Problem with setoid rewriting and reduction, Andrew Kennedy, 11/23/2012
- RE: [Coq-Club] Problem with setoid rewriting and reduction, Andrew Kennedy, 11/26/2012
- Re: [Coq-Club] Problem with setoid rewriting and reduction, Matthieu Sozeau, 11/26/2012
- RE: [Coq-Club] Problem with setoid rewriting and reduction, Andrew Kennedy, 11/27/2012
