- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Comparing objects of dependend record types
- Date: Tue, 18 Dec 2012 19:35:01 +0200
- Envelope-from: porton AT yandex.ru
Even despite I was labeled a "troll" by some members of this mailing list, I
wish to remind you my proposal for an enhancement for a future version of Coq.
I want one-line tactic scripts to prove that two objects of a dependent
record type are equal if all their data fields are equal.
Currently it is done in a very long way presented below (both is Gallina and
plain tactic scripts). And math is about making formulas shorter. Please to
effective math.
In the past I have started to formalize order/lattice theory in Coq but has
given up after realized that equality of two records is so difficult to prove.
Please hear my opinion even despite of I am a little troll: Someone should be
assigned to do this work.
Require Import Logic.ProofIrrelevance.
Parameter A : Set.
Parameter B : A -> Prop.
Structure Foo := mkFoo { a : A; b : B a }.
(*Axiom proof_irrelevance: forall (P:Prop), forall (p q:P), p=q.*)
Theorem thm (u v : Foo) : (a u = a v -> u = v).
proof.
consider x0 such that y0:(B x0) from u.
consider x1 such that y1:(B x1) from v.
assume e:(x0=x1).
claim (forall y:B x1, mkFoo x0 y0 = mkFoo x1 y). (* generalize *)
per cases on e.
suppose it is (refl_equal). (* dependent elim *)
let y':(B x0).
thus thesis by (proof_irrelevance _ y0 y'). (* automation sometimes needs
help *)
end cases.
end claim.
hence thesis.
end proof.
Qed.
Theorem thm2 (u v : Foo) : (a u = a v -> u = v).
Proof.
intros.
destruct u as [a0 b0].
destruct v as [a1 b1].
assert (a0 = a1).
assumption.
destruct H0. (* It does the magic. *)
assert (b0 = b1).
apply proof_irrelevance.
destruct H0.
reflexivity.
Qed.
Victor Porton - http://portonvictor.org
- [Coq-Club] Comparing objects of dependend record types, Victor Porton, 12/18/2012
- Re: [Coq-Club] Comparing objects of dependend record types, Olivier Uanelineur, 12/18/2012
- Re: [Coq-Club] Comparing objects of dependend record types, Victor Porton, 12/18/2012
- Re: [Coq-Club] Should I use Coq?, Jonas Oberhauser, 12/18/2012
- Re: [Coq-Club] Should I use Coq?, Marco Servetto, 12/20/2012
