coq-club - Re: [Coq-Club] Comparing objects of dependend record types
  • To: Olivier Uanelineur <o.uanelineur AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Comparing objects of dependend record types
  • Date: Tue, 18 Dec 2012 22:10:46 +0200
  • Envelope-from: porton AT yandex.ru
Olivier, it is great. My experimentation shows that it works even with records with more than one data field and more than one condition.
Based on the Olivier's work I've written a short theory which I recommend to add to Coq core (whether you'd call me a troll for this suggestion to add features or not).
(* DependentRecordEq.v *)
Require Import Logic.ProofIrrelevance.
(*Axiom proof_irrelevance: forall (P:Prop), forall (p q:P), p=q.*)
Ltac dep_rec_eq u v := intros ; destruct u ; destruct v ; simpl in * ; subst ; f_equal ; apply proof_irrelevance.
Here is the experiment which shows that this work great:
(* Test of DependentRecordEq *)
Require Import DependentRecordEq.
Parameter A0 A1 : Set.
Parameter B0 : A0 -> Prop.
Parameter B1 : A1 -> Prop.
Structure Foo := mkFoo { a0 : A0; a1: A1; b0 : B0 a0 ; b1 : B1 a1 }.
Theorem thm1 (u v : Foo) : (a0 u = a0 v -> a1 u = a1 v -> u = v).
Proof.
  dep_rec_eq u v.
Qed.
18.12.2012, 21:49, "Olivier Uanelineur" <o.uanelineur AT gmail.com>:
Hi Victor,
May I suggest this one-liner?
Parameter A : Set.
Parameter B : A -> Prop.
Structure Foo := mkFoo { a : A; b : B a }.
Theorem thm (u v : Foo) : (a u = a v -> u = v).
Proof.
Qed.
Good luck with your work,
Olivier
On Tue, Dec 18, 2012 at 5:35 PM, Victor Porton <porton AT narod.ru> wrote:
Even despite I was labeled a "troll" by some members of this mailing list, I wish to remind you my proposal for an enhancement for a future version of Coq.
I want one-line tactic scripts to prove that two objects of a dependent record type are equal if all their data fields are equal.
Currently it is done in a very long way presented below (both is Gallina and plain tactic scripts). And math is about making formulas shorter. Please to effective math.
In the past I have started to formalize order/lattice theory in Coq but has given up after realized that equality of two records is so difficult to prove.
Please hear my opinion even despite of I am a little troll: Someone should be assigned to do this work.
Parameter A : Set.
proof.
  consider x0 such that y0:(B x0) from u.
  consider x1 such that y1:(B x1) from v.
  assume e:(x0=x1).
  claim (forall y:B x1,  mkFoo x0 y0 = mkFoo x1 y). (* generalize *)
  per cases on e.
    suppose it is (refl_equal). (* dependent elim *)
    let y':(B x0).
    thus thesis by (proof_irrelevance _ y0 y'). (* automation sometimes needs help *)
  end cases.
  end claim.
  hence thesis.
end proof.
Qed.
Theorem thm2 (u v : Foo) : (a u = a v -> u = v).
Proof.
  intros.
  destruct u as [a0 b0].
  destruct v as [a1 b1].
  assert (a0 = a1).
  assumption.
  destruct H0. (* It does the magic. *)
  assert (b0 = b1).
  destruct H0.
  reflexivity.
Qed.
Victor Porton - http://portonvictor.org
