- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Should I use Coq?
- Date: Tue, 18 Dec 2012 22:53:08 +0100
Am 18.12.2012 21:27, schrieb Victor Porton:
Hi all,
Once I attempted to learn and use Coq. Then I decided not to continue with
Coq for reasons in my pre-previous email to this mailing list.
As for now, I've forgotten much of it and would need learn it anew.
With a solution offered by Olivier Uanelineur, the reason why I stopped to
use Coq disappeared.
So I am now again faced with the decision: Should I use Coq?
I'd like to formalize poset/lattice theory with Coq and afterward to
formalize my theory.
I've recently put my entire theory into one 216 A4 pages book. Now I am busy
with checking my book for errors. In any case I need to finish my (manual)
checking for errors in the book and settle it with a publisher. (And I find
many little errors while checking it.)
Is it worth to formalize my book in Coq afterward?
Dear Victor.
So apparently after finishing a project and before publishing a book, one turns to the deep questions of life.
What is my purpose in this life? Can anything I do be useful for God? Should I use Coq to formalize my book?
There are many things I would suggest if you feel like this. Let me first answer concerning the initial, Coq question. That is a tough one. I would not suggest learning Coq WHILE formalizing a 216 pages proof concerning lattice theory. You will encounter many small hardships and all of them will be very frustrating. If you have no intuition for why Coq rejected your Lemma, this "debugging" will take a ton of time. But of course developing this intuition takes time.
There are some things which are very hard to formalize in Coq and not so hard to prove on paper. Sometimes things have to be restructured. I have very little knowledge of lattice theory, so I'd be a fool to make myself a judge in this case. My rule of thumbs is that inductive types and structurally inductive proofs are very nice to formalize; everything else can become a major pain.
I have had to chew through Barras' formalization of confluence and termination of CC and I extended it by some amount. There were a few such things, like extensional equality, that Barras was able to build around. It was a very technical and hacky solution. If you're not familiar with Coq, a problem of this size might already be more than an unsatisfying technicality - it might be the death of the endeavour. Of course there is always the Coq mailinglist, where such problems can be solved - but if you'll throw the towel everytime, just like you just were doing, I can guarrantee you won't be very productive.
Apart from this, formalizing your stuff in Coq certainly is a great way to find and eliminate all the errors you have been talking of. It is not unusual to introduce a miriad of problems, forget minor cases or conditions, etc - Coq, of course, will force you to fix all of this. Apart from this, some working Coq code certainly is a great way to add credibility to your proof.
I have to admit that sometimes, when I encounter some new problem, the first thing I think about is how to formalize it in Coq. It really itches me to formalize it then. Lately I haven't had the time to do it, but it still was a great feeling whenever I did and managed to conquer the Coq. It's very rewarding in itself, if you have the time to do it.
Now on to your more severe problems. Obviously this is not the forum to discuss such things, but I can recommend this: the Jesuit order offers spiritual exercises called retreats. The interesting thing is that these services are sometimes offered for groups of atheists and non-believers as well. The idea is to find your place in the world, and answer personal questions (like the ones you ask above). The means is a few days of silence, in which you contemplate and meditate, read, discuss privately. You are guided through this quest of self-discovery by a member of the order. Even though I did not take part in such an event yet, I have heard only good things thus far. I plan to attend such an event once I have my phd (and I'll probably need it then, haha).
In any case, I hope this e-mail helped you in some way.
Kind regards, Jonas
- [Coq-Club] Comparing objects of dependend record types, Victor Porton, 12/18/2012
- Re: [Coq-Club] Comparing objects of dependend record types, Olivier Uanelineur, 12/18/2012
- Re: [Coq-Club] Comparing objects of dependend record types, Victor Porton, 12/18/2012
- Re: [Coq-Club] Should I use Coq?, Jonas Oberhauser, 12/18/2012
- Re: [Coq-Club] Should I use Coq?, Marco Servetto, 12/20/2012
