- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Multi-core execution?
- Date: Sat, 09 Mar 2013 14:27:32 -0500
This would almost work, except that Coq's term parsing and printing are
not inverses of each other. I believe almost all of my subgoals would
fail to parse back into Coq terms. On 03/09/2013 02:20 PM, Jason Gross wrote: I'm not sure if you already thought of this, but you could probably script this process, either by an OCaml plugin or a shell script: you could probably use a tactic like Ltac
display_and_solve_by_tac_or_display_db_and_admit tac x y db :=
idtac "Tactic: " tac " .
Solve Tactic: " y " . Database: " db;
x; (solve [ tac ]
|| repeat match goal
with
| [ H : _
|- _ ] => revert H
| [ H : _
|- _ ] => fail 2 "cannot revert hypothesis:" H
| [ |- ?G
] => idtac "Theorem foo : " G "." y ". Qed. Hint Immediate foo : "
db "."; admit
end).
and call it with something like [ltac:(auto with my_db)] as
[tac], some tactic as [x], some string representing a tactic as [y],
and ["my_db"] as [db], and then write a script to parse the output of
coqc, place the theorems in separate files, run coqc on them, and
construct a single file which imports all of the relevant files, and
import that file into your original file. (Admittedly, this is a
terrible hack, and probably not something you'd want to keep around in
a project.)
- [Coq-Club] Multi-core execution?, Adam Chlipala, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, AUGER Cédric, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Adam Chlipala, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Jason Gross, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Pierre-Marie Pédrot, 03/12/2013
- Re: [Coq-Club] Multi-core execution?, Adam Chlipala, 03/15/2013
- Re: [Coq-Club] Multi-core execution?, Adam Chlipala, 03/10/2013
- Re: [Coq-Club] Multi-core execution?, Pierre-Marie Pédrot, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Enrico Tassi, 03/09/2013
- Re: [Coq-Club] Multi-core execution?, Enrico Tassi, 03/10/2013
