coq-club - Re: [Coq-Club] Multi-core execution?
  • To: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Multi-core execution?
  • Date: Sat, 09 Mar 2013 14:52:59 -0500
I wouldn't expect the situation to improve much with a purely functional tactical data structure. [abstract] already does a good job of confining the chunks of work that I want to parallelize. There is a very stylized kind of side effect to [abstract] that should be trivial to merge back into the main process. In fact, the merge would be much harder without this side effect. I want to merge in proof terms associated with proved theorems, not intermediate proof search states, which could be much harder.
On 03/09/2013 02:42 PM, Pierre-Marie Pédrot wrote:
On 09/03/2013 19:34, Adam Chlipala wrote:
This doesn't sound too hard to implement from a scientific perspective,
though I'm not sure of the engineering challenges. Is anyone working on
functionality like this, or does anyone have tips on how it could be
achieved in today's Coq?
I'm unsure about how this may help, but Arnaud Spiwack's new-tacticals branch uses an almost purely functional data-structure (except for the lower-level IO primitives, which are currently not really used for proof construction) to encode the tactic monad. So you may try to write a tactic transformer using Unix.fork and message-passing to recover what you're hoping for.
Unluckily, there are two problems:
1. Minor one: the [abstract] combinator does do side-effects, by defining lemmas. So you need something more fine-grained.
2. Major one: Ltac sequence operator ";" and goal dispatch is essentially state-transforming, so most of the time, this won't work. In the [abstract] case it should be fine though, because you have no evars.
