coq-club - Re: [Coq-Club] Multi-core execution?
  • From: Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>
  • To: Adam Chlipala <adamc AT csail.mit.edu>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Multi-core execution?
  • Date: Sat, 09 Mar 2013 20:42:23 +0100
On 09/03/2013 19:34, Adam Chlipala wrote:
This doesn't sound too hard to implement from a scientific perspective,
though I'm not sure of the engineering challenges. Is anyone working on
functionality like this, or does anyone have tips on how it could be
achieved in today's Coq?
I'm unsure about how this may help, but Arnaud Spiwack's new-tacticals branch uses an almost purely functional data-structure (except for the lower-level IO primitives, which are currently not really used for proof construction) to encode the tactic monad. So you may try to write a tactic transformer using Unix.fork and message-passing to recover what you're hoping for.
Unluckily, there are two problems:
1. Minor one: the [abstract] combinator does do side-effects, by defining lemmas. So you need something more fine-grained.
2. Major one: Ltac sequence operator ";" and goal dispatch is essentially state-transforming, so most of the time, this won't work. In the [abstract] case it should be fine though, because you have no evars.
PMP
