- To: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Notation for Hoare logic
- Date: Fri, 8 Mar 2013 19:07:58 -0500
Here is an approach that works because it uses the existing notation
for " { } " and requires prefixing Hoare triples with "|-" (or some
other keyword). Hard to tell if it breaks something, though.
Inductive ht_pred : Set := ht_pred_: nat->ht_pred.
Inductive ht : ht_pred->nat->ht_pred->Prop := .
Delimit Scope htriple with htriple.
Delimit Scope htriple_pred with htriple_pred.
Arguments ht P%htriple_pred c%nat Q%htriple_pred.
Module Notations.
Notation " { P } " := (ht_pred_ P%nat) : htriple_pred.
Notation "|-" := ht (no associativity, at level 0) : htriple.
End Notations.
Module TestNotations.
Import Notations.
Open Scope htriple.
(* do existing notations still work? *)
Record Rat : Set := mkRat {
top: nat; bottom: nat; Rat_cond: (gt bottom O) }.
Goal (forall b:bool, { b=true } + { b=false }). destruct b; auto. Qed.
Goal {a | a<>false}. exists true; intro; discriminate. Qed.
Goal (forall p, {p}%htriple_pred = ht_pred_ p). reflexivity. Qed.
Goal (forall p c q,
|- {p} c {q} <-> ht (ht_pred_ p) c (ht_pred_ q)).
Proof. split; intros; auto. Qed.
End TestNotations.
-cj
- [Coq-Club] Notation for Hoare logic, Benjamin C. Pierce, 03/08/2013
- Re: [Coq-Club] Notation for Hoare logic, AUGER Cédric, 03/08/2013
- Re: [Coq-Club] Notation for Hoare logic, Benjamin C. Pierce, 03/08/2013
- Re: [Coq-Club] Notation for Hoare logic, Adam Chlipala, 03/08/2013
- Re: [Coq-Club] Notation for Hoare logic, CJ Bell, 03/09/2013
- Re: [Coq-Club] Notation for Hoare logic, Benjamin C. Pierce, 03/23/2013
