coq-club - Re: [Coq-Club] Notation for Hoare logic
  • To: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Notation for Hoare logic
  • Date: Fri, 8 Mar 2013 19:48:59 -0500
The problem with my solution is that you must write "|-{P} (1+2) {Q}"
instead of "|-{P} 1+2 {Q}". Parentheses are always required around the
command in the center because of the way that functions are parsed :/
-cj
On Fri, Mar 8, 2013 at 7:07 PM, CJ Bell
<siegebell AT gmail.com>
wrote:
> Here is an approach that works because it uses the existing notation
> for " { } " and requires prefixing Hoare triples with "|-" (or some
> other keyword). Hard to tell if it breaks something, though.
> Inductive ht_pred : Set := ht_pred_: nat->ht_pred.
> Inductive ht : ht_pred->nat->ht_pred->Prop := .
> Delimit Scope htriple with htriple.
> Delimit Scope htriple_pred with htriple_pred.
> Arguments ht P%htriple_pred c%nat Q%htriple_pred.
> Module Notations.
> Notation " { P } " := (ht_pred_ P%nat) : htriple_pred.
> Notation "|-" := ht (no associativity, at level 0) : htriple.
> End Notations.
> Module TestNotations.
> Import Notations.
> Open Scope htriple.
> (* do existing notations still work? *)
> Record Rat : Set := mkRat {
> top: nat; bottom: nat; Rat_cond: (gt bottom O) }.
> Goal (forall b:bool, { b=true } + { b=false }). destruct b; auto. Qed.
> Goal {a | a<>false}. exists true; intro; discriminate. Qed.
> Goal (forall p, {p}%htriple_pred = ht_pred_ p). reflexivity. Qed.
> Goal (forall p c q,
> |- {p} c {q} <-> ht (ht_pred_ p) c (ht_pred_ q)).
> Proof. split; intros; auto. Qed.
> End TestNotations.
> -cj
