coq-club - Re: [Coq-Club] Notation for Hoare logic
  • From: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
  • To: CJ Bell <siegebell AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Notation for Hoare logic
  • Date: Sat, 23 Mar 2013 18:23:35 -0400
Thanks to everybody for all the suggestions! I finally ended up going with
the simplest one: keeping the double-brackets and hacking the html output to
reduce the space between them. Those interested can check out how it works
in context here:
http://www.seas.upenn.edu/~cis500/current/sf/Hoare.html
I wasn't satisfied with notations that required prefixing because I want to
use the same notation for "embedded annotations" inside programs:
http://www.seas.upenn.edu/~cis500/current/sf/Hoare2.html
Same consideration applies to Greg's suggestion not to use any notation at
all.
For an application that didn't involve lots of newbies with all sorts of
different machine / ide configurations, Unicode might indeed be the best
solution...
- Benjamin
On Mar 8, 2013, at 7:48 PM, CJ Bell
wrote:
> The problem with my solution is that you must write "|-{P} (1+2) {Q}"
> instead of "|-{P} 1+2 {Q}". Parentheses are always required around the
> command in the center because of the way that functions are parsed :/
> -cj
> On Fri, Mar 8, 2013 at 7:07 PM, CJ Bell
> wrote:
>> Here is an approach that works because it uses the existing notation
>> for " { } " and requires prefixing Hoare triples with "|-" (or some
>> other keyword). Hard to tell if it breaks something, though.
>> Inductive ht_pred : Set := ht_pred_: nat->ht_pred.
>> Inductive ht : ht_pred->nat->ht_pred->Prop := .
>> Delimit Scope htriple with htriple.
>> Delimit Scope htriple_pred with htriple_pred.
>> Arguments ht P%htriple_pred c%nat Q%htriple_pred.
>> Module Notations.
>> Notation " { P } " := (ht_pred_ P%nat) : htriple_pred.
>> Notation "|-" := ht (no associativity, at level 0) : htriple.
>> End Notations.
>> Module TestNotations.
>> Import Notations.
>> Open Scope htriple.
>> (* do existing notations still work? *)
>> Record Rat : Set := mkRat {
>> top: nat; bottom: nat; Rat_cond: (gt bottom O) }.
>> Goal (forall b:bool, { b=true } + { b=false }). destruct b; auto. Qed.
>> Goal {a | a<>false}. exists true; intro; discriminate. Qed.
>> Goal (forall p, {p}%htriple_pred = ht_pred_ p). reflexivity. Qed.
>> Goal (forall p c q,
>> |- {p} c {q} <-> ht (ht_pred_ p) c (ht_pred_ q)).
>> Proof. split; intros; auto. Qed.
>> End TestNotations.
>> -cj
