coq-club - Re: [Coq-Club] Question on morphisms and "conditional" setoid rewriting
  • To: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • Cc: Coq club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question on morphisms and "conditional" setoid rewriting
  • Date: Fri, 15 Mar 2013 09:05:32 -0400
On 3/15/2013 6:12 AM, Robbert Krebbers wrote:
On 03/14/2013 08:47 PM, Ben Lerner wrote:
Or might there be a Hint form that typeclass resolution could take, to
tell it that it's ok to leave some goals unproven after normevars?
What do you expect to happen in case of overlapping instances?
Instance proper1: forall x, A x -> Proper bla (f x)
Instance proper2: forall x, B x -> Proper bla (f x)
What would you expect to happen here? A goal "A x \/ B x", to non-deterministically get the goal "A x" or "B x"? To get the goal belonging to the first declared instance?
Besides, the premisses of a hint (or instance) can also have arrows in them, making the situation even more peculiar.
Robbert
In that particular instance, it seems no more confusing than how "f_equiv" picks the first one it finds that unifies. I like the \/-construction, but I see how this could get tricky, fast. I don't see, though, how having hints with preconditions is an issue here: currently the hint either solves the goal or coq complains; so more precomditions just make it less likely to be a helpful hint.
Of course, the one unambiguous hint would be to write "rewrite ... using morphism proper1"...but at that point you're no longer needing the rewrite tactic itself...
