- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Induction on lemma proof
- Date: Fri, 15 Mar 2013 14:53:56 +0100
Hi,
If you want do try an induction on the list e, you should not
introduce too much variables as in your proof start:
intros e j (h1,h2) n h3.
Just try:
Proof.
induction e.
Then look at the generated goals (empty list, list obtained by consing
some value of type or_integer_float to a list e0).
In the last case, you may have a look at the induction hypothesis on e0.
Then you have a lot of things to do : Instantiate (if needed) some universally
quantified hypotheses, case analysis on type or_integer_float, destruct the
conjonctions in your axioms, etc.
By the way, which libraries do you use on lists ? Standard Library's List ?
Pierre
Quoting
mtkhan AT risc.uni-linz.ac.at:
Hi All,
I have a Coq goal, which is in fact translated from Why3 system.
I tried the induction on list but could not succeed. Can some
one please hint the possible proof tactics in Coq for the
following snippet of the corresponding proof.
Parameter add_int: (list or_integer_float) -> Z -> Z.
Axiom add_int_def : forall (e:(list or_integer_float)) (j:Z),
((j <= 0%Z)%Z -> ((add_int e j) = 0%Z)) /\ ((~ (j <= 0%Z)%Z) ->
((add_int e j) = match e with
| Nil => 0%Z
| (Cons (Integer n) t) => (n + (add_int t (j - 1%Z)%Z))%Z
| (Cons _ t) => (add_int t (j - 1%Z)%Z)
end)).
(* Why3 goal *)
Theorem add_int_right : forall (e:(list or_integer_float)) (j:Z),
((0%Z <= j)%Z /\ (j < (length e))%Z) -> forall (n:Z), ((nth j
e) = (Some (Integer n))) -> ((add_int e (j + 1%Z)%Z) = ((add_int e
j) + n)%Z).
which shows the following 1 goal to be proved
1 subgoal
e : list or_integer_float
j : Z
h1 : (0 <= j)%Z
h2 : (j < length e)%Z
n : Z
h3 : nth j e = Some (Integer n)
______________________________________(1/1)
add_int e (j + 1) = (add_int e j + n)%Z
Thanks.
regards,
tk
- [Coq-Club] Induction on lemma proof, mtkhan, 03/15/2013
- Re: [Coq-Club] Induction on lemma proof, Pierre Casteran, 03/15/2013
