- To: "Coq Club" <coq-club AT inria.fr>
- Subject: [Coq-Club] Mixing induction and coinduction
- Date: Sun, 21 Apr 2013 22:11:02 +0200
Inductive ne_list_bool :=
NELB : bool -> (unit + ne_list_bool) -> ne_list_bool.
CoInductive bool_flow := BF : bool -> bool_flow -> bool_flow.
Definition periodic (nelb : ne_list_bool) : bool_flow :=
cofix periodic :=
(fix per nelb_ :=
match nelb_ with
NELB b s => BF b match s with
| inl _ => periodic
| inr n => per n
end
end) nelb.
Hi all, I wanted the previous code to work.
I think I understand why it does not work, and I think I know at trick
to do what I want (the trick is simply to unroll the first recursive
call to have directly a match). But this trick is not very convenient
as I will have to do a first proof with a first unrolling and then the
recursive call.
So I am asking if it would be easy to have in the next version of Coq
an allowance of this term or the following equivalent one (which may be
easier to have):
cofix periodic :=
(fix per nelb_ :=
BF (match nelb_ with NELB b _ => b end)
(match match nelb_ with NELB _ s => s end with
| inl _ => periodic
| inr n => per n end))
nelb.
In which it is even more obvious that a call to BF will occur before
any call to periodic.
- [Coq-Club] Mixing induction and coinduction, AUGER Cédric, 04/21/2013
- Re: [Coq-Club] Mixing induction and coinduction, Pierre Boutillier, 04/22/2013
- Re: [Coq-Club] Mixing induction and coinduction, AUGER Cédric, 04/22/2013
- Re: [Coq-Club] Mixing induction and coinduction, Andreas Abel, 04/23/2013
