- To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Mixing induction and coinduction
- Date: Mon, 22 Apr 2013 20:12:55 +0200
Le Mon, 22 Apr 2013 10:32:09 +0200,
Pierre Boutillier
a
écrit :
> Hi,
> On the one hand, yes it is easy, you just have to change line 933 of
> file kernel/inductive.ml
> | _ -> raise (CoFixGuardError (env,NotGuardedForm t)) in
> by
> | Fix (rec_args,(names,types,bodies) -> something_smart
> On the other hand, something_smart has to be correct because you are
> in the kernel :-)
> Cheers,
> Pierre B.
Well in fact, I just had to change "fix" in "cofix", and it worked.
cofix is always so hard to understand for me…
> On 21/04/2013 22:11, AUGER Cédric wrote:
> > Inductive ne_list_bool :=
> > NELB : bool -> (unit + ne_list_bool) -> ne_list_bool.
> > CoInductive bool_flow := BF : bool -> bool_flow -> bool_flow.
> > Definition periodic (nelb : ne_list_bool) : bool_flow :=
> > cofix periodic :=
> > (fix per nelb_ :=
> > match nelb_ with
> > NELB b s => BF b match s with
> > | inl _ => periodic
> > | inr n => per n
> > end
> > end) nelb.
> > Hi all, I wanted the previous code to work.
> > I think I understand why it does not work, and I think I know at
> > trick to do what I want (the trick is simply to unroll the first
> > recursive call to have directly a match). But this trick is not
> > very convenient as I will have to do a first proof with a first
> > unrolling and then the recursive call.
> > So I am asking if it would be easy to have in the next version of
> > Coq an allowance of this term or the following equivalent one
> > (which may be easier to have):
> > cofix periodic :=
> > (fix per nelb_ :=
> > BF (match nelb_ with NELB b _ => b end)
> > (match match nelb_ with NELB _ s => s end with
> > | inl _ => periodic
> > | inr n => per n end))
> > nelb.
> > In which it is even more obvious that a call to BF will occur before
> > any call to periodic.
- [Coq-Club] Mixing induction and coinduction, AUGER Cédric, 04/21/2013
- Re: [Coq-Club] Mixing induction and coinduction, Pierre Boutillier, 04/22/2013
- Re: [Coq-Club] Mixing induction and coinduction, AUGER Cédric, 04/22/2013
- Re: [Coq-Club] Mixing induction and coinduction, Andreas Abel, 04/23/2013
