- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Mixing induction and coinduction
- Date: Tue, 23 Apr 2013 10:17:37 +0200
On 22.04.13 8:12 PM, AUGER Cédric wrote:
Well in fact, I just had to change "fix" in "cofix", and it worked.
cofix is always so hard to understand for me…
Ah, yes, since the "recursive" call "per n" is also under the guard "BF b", you can change it into a corecursive call.
You can fuse the nested fixed-points as follows:
Definition periodic (nelb : ne_list_bool) : bool_flow :=
(cofix periodic nelb_ :=
match nelb_ with
NELB b s => BF b match s with
| inl _ => periodic nelb
| inr n => periodic n
end
end) nelb.
But in general, your suggestion to relax the guard condition would be useful. See also
Mixed Inductive/Coinductive Types and Strong Normalization
http://www2.tcs.ifi.lmu.de/~abel/publications.html#aplas07
Cheers,
Andreas
On 21/04/2013 22:11, AUGER Cédric wrote:
Inductive ne_list_bool :=
NELB : bool -> (unit + ne_list_bool) -> ne_list_bool.
CoInductive bool_flow := BF : bool -> bool_flow -> bool_flow.
cofix periodic :=
(fix per nelb_ :=
match nelb_ with
| inl _ => periodic
| inr n => per n
end
end) nelb.
Hi all, I wanted the previous code to work.
I think I understand why it does not work, and I think I know at
trick to do what I want (the trick is simply to unroll the first
recursive call to have directly a match). But this trick is not
very convenient as I will have to do a first proof with a first
unrolling and then the recursive call.
So I am asking if it would be easy to have in the next version of
Coq an allowance of this term or the following equivalent one
(which may be easier to have):
cofix periodic :=
(fix per nelb_ :=
BF (match nelb_ with NELB b _ => b end)
(match match nelb_ with NELB _ s => s end with
| inl _ => periodic
| inr n => per n end))
nelb.
In which it is even more obvious that a call to BF will occur before
any call to periodic.
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
- [Coq-Club] Mixing induction and coinduction, AUGER Cédric, 04/21/2013
- Re: [Coq-Club] Mixing induction and coinduction, Pierre Boutillier, 04/22/2013
- Re: [Coq-Club] Mixing induction and coinduction, AUGER Cédric, 04/22/2013
- Re: [Coq-Club] Mixing induction and coinduction, Andreas Abel, 04/23/2013
