Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?
- Date: Wed, 24 Apr 2013 08:39:08 -0400
On 04/24/2013 06:35 AM, Bai Wei wrote:
Hi. I want to implement Foundatinal proof carrying code (FPCC) paradigm. Does Coq proof checker can be used as a proof checker in FPCC? Many Thanks!
There's a good chance that the answer is "yes." Certainly several research groups are using Coq in that way, though I don't know if anyone's bothering to check proofs with the minimized Coq checker regularly. If you have more specific requirements, you might get a better response after sharing them.
- [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Bai Wei, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Jonas Oberhauser, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Adam Chlipala, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Duckki Oe, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Amy Felty, 04/25/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Amy Felty, 04/28/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Gabriel Scherer, 04/29/2013
