Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?
- To: Bai Wei <baiweiyj AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?
- Date: Sat, 27 Apr 2013 20:42:31 -0400
I have implemented FPCC in Coq as part of the work for this paper: http://www.site.uottawa.ca/~afelty/dist/fi07.pdf. The Coq scripts are not available electronically, but I can make them available if that is what you are looking for.
Regards,
Amy Felty
On 24/04/2013 6:35 AM, Bai Wei wrote:
Hi. I want to implement Foundatinal proof carrying code (FPCC) paradigm. Does Coq proof checker can be used as a proof checker in FPCC? Many Thanks!
Cheers,
Wei Bai
- [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Bai Wei, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Jonas Oberhauser, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Adam Chlipala, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Duckki Oe, 04/24/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Amy Felty, 04/25/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Amy Felty, 04/28/2013
- Re: [Coq-Club] Does Coq proof checker can be used as a proof checker in Foundational PCC paradigm?, Gabriel Scherer, 04/29/2013
