- From: Gabriel Scherer <gabriel.scherer AT gmail.com>
- To: Math Prover <mathprover AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Ltac Debugging
- Date: Sat, 25 May 2013 10:39:06 +0200
> 1) What am I doing wrong in this particular example?
Given that your hypothesis is (A = (3,4) /\ (x,y) = A), you apparently
want to destruct over (foo /\ bar) rather than (foo * bar). Changing
your tactic from
match goal with
| p: ?K * ?V |- _ => ...
to
match goal with
| p: ?K /\ ?V |- _ => ...
works fine on my machine.
> I don't know emacs. I don't know proof general. Is there any other way to
> debug ltac?
I'm not sure what you mean by "debug Ltac", but regarding coq-modes,
you may consider giving Emacs a try (it is rather easy to use in a
simple way, and I know some long-time vimers use Emacs just for
Proof-General). There is also a fairly young project or providing a
proof-general-like interface for Vim, named "Coquille" (
https://github.com/trefis/coquille ). It's in an early stage of
development, but you may give it a try.
On Sat, May 25, 2013 at 10:19 AM, Math Prover
wrote:
> There are two separate questions here:
> 1) What am I doing wrong in this particular example and
> 2) What should I use in general?
> ### What am I doing wrong in this example?
> I want a tactic that destructs pairs (this is not what I want to do, this is
> my minimal failure case). Yet, when I type in "tac00", I get:
> |Error: No matching clauses for match goal
> | (use "Set Ltac Debug" for more info).
> ### How do I debug Ltac?
> I have used Vim for 10+ years. I have used both CoqIde and Matthieu
> Cartier's http://www.vim.org/scripts/script.php?script_id=4388 .
> debug ltac?
> Thanks!
- [Coq-Club] Ltac Debugging, Math Prover, 05/25/2013
- Re: [Coq-Club] Ltac Debugging, Gabriel Scherer, 05/25/2013
- Re: [Coq-Club] Ltac Debugging, AUGER Cédric, 05/25/2013
- Re: [Coq-Club] Ltac Debugging, Math Prover, 05/25/2013
- Re: [Coq-Club] Ltac Debugging, Jason Gross, 05/25/2013
- Re: [Coq-Club] Ltac Debugging, Alan Schmitt, 05/25/2013
- Re: [Coq-Club] Ltac Debugging, Wojciech Meyer, 05/26/2013
- Re: [Coq-Club] Ltac Debugging, Math Prover, 05/26/2013
