coq-club - Re: [Coq-Club] Ltac Debugging
  • To: AUGER Cédric <sedrikov AT gmail.com>
  • Cc: Gabriel Scherer <gabriel.scherer AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Ltac Debugging
  • Date: Sat, 25 May 2013 02:16:26 -0700
In which case, why did Coq accept the Ltac, but not apply it? It seems to me if it didn't recognize the syntax, then the error should have happened when I defined tac00"
On Sat, May 25, 2013 at 2:15 AM, Math Prover <mathprover AT gmail.com> wrote:
Gabriel: I want to destruct the product, not the and. Thanks for pointing me at https://github.com/trefis/coquille
Auger: this fixed it, thanks!
So I guess my problem was: "*" notation syntax is not supported in Ltac?
On Sat, May 25, 2013 at 2:06 AM, AUGER Cédric <sedrikov AT gmail.com> wrote:
Le Sat, 25 May 2013 10:39:06 +0200,
Gabriel Scherer <gabriel.scherer AT gmail.com> a écrit :
> > 1) What am I doing wrong in this particular example?
> Given that your hypothesis is (A = (3,4) /\ (x,y) = A), you apparently
> want to destruct over (foo /\ bar) rather than (foo * bar). Changing
> your tactic from
> match goal with
>   | p: ?K * ?V |- _ => ...
> to
> match goal with
>   | p: ?K /\ ?V |- _ => ...
> works fine on my machine.
Well, I guess that he wants to destruct (A : prod nat nat) rather than
(H : A = (3, 4) ∧ (x, y) = A).
I did not tested it, but what happens if you replace "p : ?K * ?V" with
"p : prod ?K ?V"?
I do not know if in these conditions type_scope is active, or if it is
nat_scope.
> > I don't know emacs. I don't know proof general. Is there any other
> > way to debug ltac?
> I'm not sure what you mean by "debug Ltac", but regarding coq-modes,
> you may consider giving Emacs a try (it is rather easy to use in a
> simple way, and I know some long-time vimers use Emacs just for
> Proof-General). There is also a fairly young project or providing a
> proof-general-like interface for Vim, named "Coquille" (
> https://github.com/trefis/coquille ). It's in an early stage of
> development, but you may give it a try.
> On Sat, May 25, 2013 at 10:19 AM, Math Prover <mathprover AT gmail.com>
> wrote:
> > There are two separate questions here:
> > 1) What am I doing wrong in this particular example and
> > 2) What should I use in general?
> > ### What am I doing wrong in this example?
> > I want a tactic that destructs pairs (this is not what I want to
> > do, this is my minimal failure case). Yet, when I type in "tac00",
> > I get:
> > |Error: No matching clauses for match goal
> > |       (use "Set Ltac Debug" for more info).
> > ### How do I debug Ltac?
> > I have used Vim for 10+ years. I have used both CoqIde and Matthieu
> > Cartier's http://www.vim.org/scripts/script.php?script_id=4388 .
> > way to debug ltac?
> > Thanks!
