coq-club - Re: [Coq-Club] Ltac Debugging
  • To: Math Prover <mathprover AT gmail.com>
  • Cc: Gabriel Scherer <gabriel.scherer AT gmail.com>, "coq-club\@inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Ltac Debugging
  • Date: Sun, 26 May 2013 02:15:23 +0100
Sure, but I'm also not very accustomed with Ltac yet. That was a general
comment.
> Given that your hypothesis is (A = (3,4) /\ (x,y) = A), you apparently
> want to destruct over (foo /\ bar) rather than (foo * bar).
Wouldn't `split' or `elim' tactic combined with `destruct' work?
It does not mean it's the only way however.
best,
Wojciech
Math Prover
writes:
> On Sat, May 25, 2013 at 5:45 PM, Wojciech Meyer
> <wojciech.meyer AT gmail.com>
> wrote:
> As a side comment (nothing to do with the excellent Gabriel's
> comment):
> So in general, I don't like to use pattern of Ltac, I rather use
> bare
> (well, let's say basic) tactics to do this.
> I'm new to Ltac / automated proving. Can you provide an example of how
> "bare tactics" would work in the above example? [It's likely that I'm
> doing terribly un-idiomatic things without even realizing that they're
> stupid.]
> Ltac should be used in most
> general cases where you want automated decisions rather than whole
> tactic language. Surely that does not work always, but works for
> me. And
> that's not because that Ltac is not simple enough, it's because it
> has
> to be used for high level proofs. Also although Ltac is just very
> pleasant to use, but should one should not fell into this trap so,
> it's
> just even much better to do this for the other single or
> collection of
> proofs even in the other module that needed automated decisions
> and
> separate carefully the Ltac bits.
> Wojciech
> Gabriel Scherer
> writes:
> >> 1) What am I doing wrong in this particular example?
> apparently
> Changing
> > your tactic from
> > match goal with
> >   | p: ?K * ?V |- _ => ...
> > to
> > match goal with
> >   | p: ?K /\ ?V |- _ => ...
> > works fine on my machine.
> >> I don't know emacs. I don't know proof general. Is there any
> other way to
> >> debug ltac?
> > I'm not sure what you mean by "debug Ltac", but regarding
> coq-modes,
> > you may consider giving Emacs a try (it is rather easy to use in
> a
> > simple way, and I know some long-time vimers use Emacs just for
> > Proof-General). There is also a fairly young project or
> providing a
> > proof-general-like interface for Vim, named "Coquille" (
> > https://github.com/trefis/coquille ). It's in an early stage of
> > development, but you may give it a try.
> > On Sat, May 25, 2013 at 10:19 AM, Math Prover
> wrote:
> >> There are two separate questions here:
> >> 1) What am I doing wrong in this particular example and
> >> 2) What should I use in general?
> >> ### What am I doing wrong in this example?
> >> I want a tactic that destructs pairs (this is not what I want
> to do,
> >> this is
> >> my minimal failure case). Yet, when I type in "tac00", I get:
> >> |Error: No matching clauses for match goal
> >> |       (use "Set Ltac Debug" for more info).
> >> ### How do I debug Ltac?
> >> I have used Vim for 10+ years. I have used both CoqIde and
> Matthieu
> >> Cartier's http://www.vim.org/scripts/script.php?script_id=4388
> other way to
> >> debug ltac?
> >> Thanks!
Wojciech
