- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner question -- equality of types
- Date: Mon, 03 Jun 2013 15:48:48 -0400
On 06/03/2013 03:42 PM, Kevin Sullivan wrote: On Mon, Jun 3, 2013 at 12:38 PM, Adam
Chlipala <adamc AT csail.mit.edu>
wrote:
universes I can see that
if you can define types as sets of elements satisfying arbitrary
specifications, then to solve the particular equality problem I used as
an example, in general, would be to solving program equivalence.
Bzzzt. That said, I'd be happy with just name or syntactic equivalence.
I think what you are saying is that even that level of computation with
types as values is out of reach in Coq. Correct?
Right. The feature that prevents analysis of types is often presented as a big advantage of type theories. It's often called "parametricity" and said to underlie abstract datatypes and abstraction via modules or classes. Coq lacks
functionalities to "destruct/inspect" and/or "construct" type
definitions.
Well, I'd say Coq's logic Gallina lacks case analysis over types, but certainly allows very rich forms of constructing new types from old ones. And the answer is to build my own type
system within Coq and to use its types, rather than Coq types, to do
what I want?
Quite possibly, though we'd need more context to give advice at that level of detail. |
- [Coq-Club] Beginner question -- equality of types, Kevin Sullivan, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Adam Chlipala, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Math Prover, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Kevin Sullivan, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Greg Morrisett, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Frédéric Besson, 06/07/2013
- Re: [Coq-Club] Beginner question -- equality of types, Gregory Malecha, 06/07/2013
- Re: [Coq-Club] Beginner question -- equality of types, Jonas Oberhauser, 06/05/2013
