coq-club - Re: [Coq-Club] Beginner question -- equality of types
  • To: Kevin Sullivan <sullivan.kevinj AT gmail.com>
  • Cc: Adam Chlipala <adamc AT csail.mit.edu>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Beginner question -- equality of types
  • Date: Mon, 3 Jun 2013 17:10:56 -0400
Hi Kevin,
The usual way around this is to define syntax for types e.g.,:
Inductive tipe : Set :=
| Nat : tipe
| Pair : tipe -> tipe -> tipe
| Arrow : tipe -> tipe -> tipe.
and then an interpretation of your syntax back into semantics:
Fixpoint interp(t:tipe) : Set :=
match t with
| Nat => nat
| Pair t1 t2 => (interp t1) * (interp t2)
| Arrow t1 t2 => (interp t1) -> (interp t2)
end%type.
Then you can define equivalence on tipes e.g.:
Definition tipe_eq : forall (t1 t2:tipe), {t1=t2}+{t1<>t2}.
decide equality.
Defined.
This gets trickier when you have complicated types (e.g.,
polymorphism or dependent types).
-Greg
On Jun 3, 2013, at 3:42 PM, Kevin Sullivan
wrote:
> On Mon, Jun 3, 2013 at 12:38 PM, Adam Chlipala
> wrote:
> universes
> I can see that if you can define types as sets of elements satisfying
> arbitrary specifications, then to solve the particular equality problem I
> used as an example, in general, would be to solving program equivalence.
> Bzzzt. That said, I'd be happy with just name or syntactic equivalence. I
> think what you are saying is that even that level of computation with types
> as values is out of reach in Coq. Correct? Coq lacks functionalities to
> "destruct/inspect" and/or "construct" type definitions. E.g., to write a
> function that takes a type and returns a type that is a composition of that
> type with some new type information. Have I basically got this right?
> And the answer is to build my own type system within Coq and to use its
> types, rather than Coq types, to do what I want?
> Kevin
