- To: Kevin Sullivan <sullivan.kevinj AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner question -- equality of types
- Date: Wed, 05 Jun 2013 16:49:47 +0200
Am 03.06.2013 18:25, schrieb Kevin Sullivan:
Hi folks, sorry for a newbie question. I've started playing around with types as values, but I'm not sure how to do simple computations with such values. One such computation would be comparison for equality. I'm obviously missing some basic knowlege. Here's a simple but broken program that should make my intent clear. What do I need to go read to make this work? Thanks!
Definition teq (t1 t2: Set) : bool :=
if (t1 = t2) then true else false.
Kevin
Hi Kevin,
since you consider yourself a beginner (considering Coq) I'd like to mention the following:
Recall that "if (a : A) then x else y" is basically equal to "match a with first constructor of A => x | second constructor of A => y end"; there is no magic in your if that could decide anything about the "truth value" or something like that of the proposition (t1 = t2). Prop is not inductive and doesn't have constructors in this sense, and especially not two - so it isn't very surprising that the if doesn't work.
Recall that if you assume classical logic, you get something like: (xm : (forall p : Prop, p \/ ~p)). Note that (xm (t1 = t2)) has type (t1 = t2 \/ t1 <> t2). Recall that (t1 = t2 \/ t1 <> t2) is an inductive type with two constructors. Therefore, (if xm (t1 = t2) then true else false) would work the way you imagine.
I believe that there was a level-mismatch between what you plugged into the if (a proposition) and what should be in the if (something that decides whether that proposition holds or not). I also fell for this when I first came into contact with Coq and I think it stems from the syntax "if a == b then ..." common in other programming languages.
Note that if you would give the type of the expression (a == b) in Coq, it would not be Prop; it could be, among other things, bool or {x=y} \/ {x<>y} (and both of these types have two constructors).
To sum it up, the proposition (a=b) and the decision procedure "a == b" are very different and live on different levels. Recall that you can give a procedure like "==" for elements of nat and many other types. "if 1 = 3 then x else y" is not meaningful in Coq, while if 1 == 3 then x else y is (when x == y is a notation for, e.g., eq_nat_dec x y).
Kind regards and hoping that this helped, Jonas
- [Coq-Club] Beginner question -- equality of types, Kevin Sullivan, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Adam Chlipala, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Math Prover, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Kevin Sullivan, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Greg Morrisett, 06/03/2013
- Re: [Coq-Club] Beginner question -- equality of types, Frédéric Besson, 06/07/2013
- Re: [Coq-Club] Beginner question -- equality of types, Gregory Malecha, 06/07/2013
- Re: [Coq-Club] Beginner question -- equality of types, Jonas Oberhauser, 06/05/2013
