- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Order of subgoals due [rewrite] and [replace]
- Date: Sat, 15 Jun 2013 22:55:26 +0200
Hello,
when using the [rewrite] or [replace] tactic, new subgoals may be generated. These subgoals appear _after_ the current goal, instead of _before_ the new goal. This is rather awkward if one intends to write structured proof scripts. Consider:
Require Import NPeano.
Goal forall x y z : nat,
x < y -> z + ((1 + y) + (x - (1 + y))) = x + z.
intros x y z Hxy.
rewrite <-Minus.le_plus_minus.
(* 1st goal: [z + x = x + z],
the goal in which the rewrite has been performed
2nd goal: [1 + y <= x],
the side condition of the rewrite *)
Since the subgoal for the side condition of the rewrite justifies the rewrite, it is much natural for it to appear first. That way, it is straight below the rewrite in the proof script. Especially when having multiple rewrites, the current behavior gives incomprehensible proof scripts, and having the subgoal for the side condition first would improve that a lot.
Besides, this behavior is inconsistent with other tactics as [assert] and [destruct], which put subgoals for their side conditions first. Also, it does not combine nicely with brackets in proof scripts. When performing a [destruct] I often write:
destruct foo as [bar baz baq].
{ intros. (* prove side condition here *) }
whereas for rewrite that's not possible as the subgoals appear in the "wrong" order.
Is there any reason for this behavior, apart from backwards compatibility? Or is there a flag to change it?
Cheers,
Robbert
PS: I know of "[rewrite foo by tac]" but then I have to write the whole proof of the side condition using a single tactic.
- [Coq-Club] Order of subgoals due [rewrite] and [replace], Robbert Krebbers, 06/15/2013
- Re: [Coq-Club] Order of subgoals due [rewrite] and [replace], Arnaud Spiwack, 06/17/2013
- Re: [Coq-Club] Order of subgoals due [rewrite] and [replace], Robbert Krebbers, 06/17/2013
- Re: [Coq-Club] Order of subgoals due [rewrite] and [replace], Enrico Tassi, 06/17/2013
