coq-club - Re: [Coq-Club] Order of subgoals due [rewrite] and [replace]
  • From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • To: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Order of subgoals due [rewrite] and [replace]
  • Date: Mon, 17 Jun 2013 10:34:52 +0200
There is indeed: rewrites at least are supposed to be chained, even when they have side conditions. It's easier to chain them if the main goal is the first one (of course, it is less so nowadays that there is the [ .. | tac ] syntax which allows to apply a tactic to the last goal).
Coq carries a lot of history, that's true.
And on a related note, I still haven't brought myself to write a tactic to reorder goals. Mostly because I haven't settled on the syntax.
On 15 June 2013 22:55, Robbert Krebbers <mailinglists AT robbertkrebbers.nl> wrote:
Hello,
when using the [rewrite] or [replace] tactic, new subgoals may be generated. These subgoals appear _after_ the current goal, instead of _before_ the new goal. This is rather awkward if one intends to write structured proof scripts. Consider:
  Require Import NPeano.
  Goal forall x y z : nat,
    x < y -> z + ((1 + y) + (x - (1 + y))) = x + z.
  intros x y z Hxy.
  rewrite <-Minus.le_plus_minus.
  (* 1st goal: [z + x = x + z],
       the goal in which the rewrite has been performed
     2nd goal: [1 + y <= x],
       the side condition of the rewrite *)
Since the subgoal for the side condition of the rewrite justifies the rewrite, it is much natural for it to appear first. That way, it is straight below the rewrite in the proof script. Especially when having multiple rewrites, the current behavior gives incomprehensible proof scripts, and having the subgoal for the side condition first would improve that a lot.
Besides, this behavior is inconsistent with other tactics as [assert] and [destruct], which put subgoals for their side conditions first. Also, it does not combine nicely with brackets in proof scripts. When performing a [destruct] I often write:
  destruct foo as [bar baz baq].
  { intros. (* prove side condition here *) }
whereas for rewrite that's not possible as the subgoals appear in the "wrong" order.
Is there any reason for this behavior, apart from backwards compatibility? Or is there a flag to change it?
Cheers,
Robbert
PS: I know of "[rewrite foo by tac]" but then I have to write the whole proof of the side condition using a single tactic.
