- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Re: coqide / ltac support
- Date: Sun, 16 Jun 2013 02:19:00 -0700
Figured it out. I want:
match goal with
| |- context [if ?tst then _ else _ ] => destruct tst
end.
instead.
However, 1) I have no idea why this works; and 2) I still don't know how to use proof-general/ltac. :-)
On Sun, Jun 16, 2013 at 1:20 AM, Math Prover <mathprover AT gmail.com> wrote:
Hi,I've installed proof-general and set "Set Ltac Debug." This is the results from just hitting <enter>. Can someone help me get started on debugging this? (This is installed on a separate machine; it has Coq 8.4pl2 compiled from source; but not access to CpdtTactics).The details of what I'm using:x@ubuntu:~$ proofgeneral --versionGNU Emacs 23.4.1Copyright (C) 2012 Free Software Foundation, Inc.GNU Emacs comes with ABSOLUTELY NO WARRANTY.You may redistribute copies of Emacsunder the terms of the GNU General Public License.For more information about these matters, see the file named COPYING.x@ubuntu:~$ coqtop -vThe Coq Proof Assistant, version 8.4pl2 (June 2013)compiled on Jun 16 2013 00:41:24 with OCaml 3.12.1On Sat, Jun 15, 2013 at 11:52 PM, Math Prover <mathprover AT gmail.com> wrote:Hi,I'm clearly doing something very stupid with ltac / match goal. However, it's not clear to me where my stupidity lies.Attached is a minimal example of failure.In particular, I can't:(*) break ifs(*) break pairs
Please let me know what I'm mis-using. To help debug my error, here is my mental model of how things *should* work
Take for exampleLtac break_if :=match goal with| [ |- context [if ?tst then _ else _]] => destruct tstend.when I run "break_if" I expect the following to happen:1. Coq looks at my current state.2. It tries to find a "sub _expression_" of the goal that looks like "if ?tst then _ else _"3. I expect ?tst to be binding against either " Keq k1 k' " or " Keq k2 k' " (I actually don't care which).4. Then, I expect coq to do a " destruct (Keq k1 k') " or a " destruct (Keq k2 k') "Thanks!
- [Coq-Club] coqide / ltac support, Math Prover, 06/16/2013
- Message not available
- [Coq-Club] Re: coqide / ltac support, Math Prover, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Pierre Casteran, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Math Prover, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Jason Gross, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Math Prover, 06/17/2013
- Re: [Coq-Club] coqide / ltac support, Pierre Courtieu, 06/17/2013
