coq-club - Re: [Coq-Club] coqide / ltac support
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Math Prover <mathprover AT gmail.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coqide / ltac support
  • Date: Sun, 16 Jun 2013 14:01:39 +0200
Hi,
I looked at your attached file:
On which kind of examples break_if doesn't work ?
On a small example, it works, as well as some variants I attached to this mail.
break_pair1 seems to work to, although it works only on goals containing an equality (?x,?y)=t
But I don't understand how to use break_pair2 :
It would need an equality of the form (T1 * T2) = T3, but how to destruct T3 ??
Pierre
Quoting Math Prover
<mathprover AT gmail.com>:
Hi,
I'm clearly doing something very stupid with ltac / match goal. However,
it's not clear to me where my stupidity lies.
Attached is a minimal example of failure.
In particular, I can't:
(*) break ifs
(*) break pairs
Please let me know what I'm mis-using. To help debug my error, here is my
mental model of how things *should* work
Take for example
Ltac break_if :=
match goal with
| [ |- context [if ?tst then _ else _]] => destruct tst
end.
when I run "break_if" I expect the following to happen:
1. Coq looks at my current state.
2. It tries to find a "sub expression" of the goal that looks like "if
?tst then _ else _"
3. I expect ?tst to be binding against either " Keq k1 k' " or " Keq k2
k' " (I actually don't care which).
4. Then, I expect coq to do a " destruct (Keq k1 k') " or a " destruct
(Keq k2 k') "
Thanks!
Require Import List.
Section assocList.
  Variable K: Type.
  Variable V: Type.
  Variable Keq: forall k1 k2: K, {k1 = k2} + {k1 <> k2}.
  Variable Veq: forall v1 v2: V, {v1 = v2} + {v1 <> v2}.
  Function assocList_r (lst: list (K * V)) (k: K) (d: V) : V :=
    match lst with
    | nil => d
    | (k',v') :: xs => if Keq k k' then v' else assocList_r xs k d
    end.
  Function assocList_del (lst: list (K * V)) (k: K) : list (K * V) :=
    match lst with
    | nil => nil
    | (k',v') :: xs => if Keq k k' then assocList_del xs k else (k',v') :: assocList_del xs k
    end.
  Function assocList_w (lst: list (K * V)) (k: K) (v: V) : list (K * V) :=
    (k,v) :: assocList_del lst k.
  Ltac break_if:=
    match goal with
    end.
 Ltac break_if':=
    match goal with
    | [ |- context [if ?tst then _ else _]] => case_eq tst
    end.
Ltac break_if'' tst :=
    match goal with
    | [ |- context [if tst then _ else _]] => case_eq tst
    end.
  Ltac break_pair1 :=
    match goal with
    | [ |- context [ (_, _) = ?a ]] => destruct a
    end.
  Ltac break_pair2 :=
    match goal with
    | [ |- context [ prod _ _ = ?a ]] => destruct a
    end.
Goal forall b:bool, (if b then 1 else 2) = (if (negb b) then 2 else 1).
intro b.
break_if.
break_if'' (negb true).
discriminate.
auto.
auto.
Qed.
Goal forall (n p:nat) x, (n,p) = x -> n = fst x.
intros n p x; break_pair1.
now injection 1.
Qed.
