- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: Pierre Casteran <pierre.casteran AT labri.fr>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coqide / ltac support
- Date: Sun, 16 Jun 2013 16:55:39 -0700
Pierre, Jason:
This makes sense now. My failure in understanding was exactly this:
Pierre:
>> Anyway, your fail.v example works with your break_if tactic once I destruct the
a in the "let (k',v') := a in <term> "Jason:
>> The problem is that k' and v' are meaningless at top level; a manual [destruct Keq k1 k'] will fail because Coq doesn't know what k' is.
I can best phrase my previous failure as follows: "Those variables don't exist until you break the let; therefore you can't destruct on them until you destruct the let first."
Anyway, thanks for everyone's help in debugging my confusing question.
On Sun, Jun 16, 2013 at 9:09 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
The problem is that k' and v' are meaningless at top level; a manual [destruct Keq k1 k'] will fail because Coq doesn't know what k' is.You could do something likerepeat match goal with | [ |- appcontext[match ?E with _ => _ end] ] => destruct E endto destruct both the lets and the ifs, though it might be a bit more powerful than you want.-JasonOn Sun, Jun 16, 2013 at 11:07 AM, Pierre Casteran <pierre.casteran AT labri.fr> wrote:
Hu,
I'm not sure the "context" notion in Ltac captures subterms of
match or destructuring let expressions (Perhaps someone in the list will confirm ?)
I attach a solution that works. It is not well written in cpdt's sense, but writing
Coq scripts while listening at John Coltrane's music is a quite difficult exercise :-)
Pierre
Quoting Math Prover <mathprover AT gmail.com>:
Hi Pierre,
With apologies for not making this clear: it does not work on the fail.v
I attached. I'm using Coq 8.4pl2.
In particular, on line 79, if I try to use either "break_if" or
"break_pair1", Coq complains and says it can't match the pattern.
"break_pair2" is me being stupid and misreading the constructor for pair.
On Sun, Jun 16, 2013 at 5:01 AM, Pierre Casteran
<pierre.casteran AT labri.fr>wrote:
Hi,
I looked at your attached file:
On which kind of examples break_if doesn't work ?
On a small example, it works, as well as some variants I attached to this
mail.
break_pair1 seems to work to, although it works only on goals containing
an equality (?x,?y)=t
But I don't understand how to use break_pair2 :
It would need an equality of the form (T1 * T2) = T3, but how to
destruct T3 ??
Pierre
Hi,
I'm clearly doing something very stupid with ltac / match goal. However,
it's not clear to me where my stupidity lies.
Attached is a minimal example of failure.
In particular, I can't:
(*) break ifs
(*) break pairs
Please let me know what I'm mis-using. To help debug my error, here is
my
mental model of how things *should* work
Take for example
Ltac break_if :=
match goal with
| [ |- context [if ?tst then _ else _]] => destruct tst
end.
when I run "break_if" I expect the following to happen:
1. Coq looks at my current state.
2. It tries to find a "sub _expression_" of the goal that looks like "if
?tst then _ else _"
3. I expect ?tst to be binding against either " Keq k1 k' " or " Keq k2
k' " (I actually don't care which).
4. Then, I expect coq to do a " destruct (Keq k1 k') " or a " destruct
(Keq k2 k') "
Thanks!
- [Coq-Club] coqide / ltac support, Math Prover, 06/16/2013
- Message not available
- [Coq-Club] Re: coqide / ltac support, Math Prover, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Pierre Casteran, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Math Prover, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Jason Gross, 06/16/2013
- Re: [Coq-Club] coqide / ltac support, Math Prover, 06/17/2013
- Re: [Coq-Club] coqide / ltac support, Pierre Courtieu, 06/17/2013
