coq-club - Re: [Coq-Club] type class instance inference
  • To: Gert Smolka <smolka AT ps.uni-saarland.de>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] type class instance inference
  • Date: Fri, 21 Jun 2013 11:43:27 +0200
Dear Gert,
Actually, this is not a bug… Requiring List sets [not] as an opaque constant
for typeclass inference, hence it is no longer unfolded while searching
for a proof of [dec (~ X)], which fails. You can [Print HintDb
typeclass_instances]
to see which definitions are considered opaque at any given point.
Declaring [Typeclasses Transparent not.] after the import reverts that
setting
and resolution works as before.
Best,
-- Matthieu
Le 18 juin 2013 à 14:41, Gert Smolka
a écrit :
> I stumbled across a very strange behavior of type class inference.
> Definition dec (X : Prop) : Type := {X} + {~ X}.
> Definition decision (X : Prop) (D : dec X) : dec X := D.
> Arguments decision X {D}.
> Existing Class dec.
> Instance False_dec : dec False :=
> right (fun A => A).
> Instance impl_dec (X Y : Prop) : dec X -> dec Y -> dec (X -> Y).
> Proof. unfold dec ; tauto. Qed.
> Set Printing Implicit.
> Check (fun (X : Prop) (D : dec X) => decision (~ X)).
> Require List.
> In the first Check the class argument is derived, in the second it is not.
> Both Checks are identical, the difference stems from requiring List in
> between.
> Is this a bug or a feature? Gert
