- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] type class instance inference
- Date: Fri, 21 Jun 2013 14:39:42 +0200
Dear Matthieu,
thanks for the explanation. I understand.
But there is an obvious next question: Why are "not" and "iff" made opaque by
List (and other standard modules)?
Gert
On Jun 21, 2013, at 11:43 , Matthieu Sozeau
wrote:
> Dear Gert,
> Actually, this is not a bug… Requiring List sets [not] as an opaque
> constant
> for typeclass inference, hence it is no longer unfolded while searching
> for a proof of [dec (~ X)], which fails. You can [Print HintDb
> typeclass_instances]
> to see which definitions are considered opaque at any given point.
> Declaring [Typeclasses Transparent not.] after the import reverts that
> setting
> and resolution works as before.
> Best,
> -- Matthieu
> Le 18 juin 2013 à 14:41, Gert Smolka
> <smolka AT ps.uni-saarland.de>
> a écrit :
>> I stumbled across a very strange behavior of type class inference.
>> Definition dec (X : Prop) : Type := {X} + {~ X}.
>> Definition decision (X : Prop) (D : dec X) : dec X := D.
>> Arguments decision X {D}.
>> Existing Class dec.
>> Instance False_dec : dec False :=
>> right (fun A => A).
>> Instance impl_dec (X Y : Prop) : dec X -> dec Y -> dec (X -> Y).
>> Proof. unfold dec ; tauto. Qed.
>> Set Printing Implicit.
>> Check (fun (X : Prop) (D : dec X) => decision (~ X)).
>> Require List.
>> In the first Check the class argument is derived, in the second it is not.
>> Both Checks are identical, the difference stems from requiring List in
>> between.
>> Is this a bug or a feature? Gert
- [Coq-Club] type class instance inference, Gert Smolka, 06/18/2013
- Re: [Coq-Club] type class instance inference, Matthieu Sozeau, 06/21/2013
- Re: [Coq-Club] type class instance inference, Gert Smolka, 06/21/2013
