- To: coq-club AT inria.fr
- Subject: Fwd: [Coq-Club] Excluded Middle for Type?
- Date: Tue, 2 Jul 2013 22:00:45 +0200
Hi,
first of all, sorry for not sending this to the whole list at first. Secondly I believe that
dit : forall T: Type, T + T -> False
is equivalent to XM and AC.
The 'dit' stands for decidable inhabitance of types in the sense of for each type you can obtain either a member or a proof that no such member exists (whether one should still call this deciding is of course debatable)
ragards
Jonas
Jonas Kaiser
Saarbrücken
---------- Forwarded message ----------
Date: 2 July 2013 21:52
Subject: Re: [Coq-Club] Excluded Middle for Type?
To: Chris Casinghino <chris.casinghino AT gmail.com>
Jonas Kaiser
Saarbrücken
Hi Chris,
afaik it follwos from assuming EM for Prop and the Axiom of Choice (in the sense of the Epsilon Library)
cheers
Jonas
On 2 July 2013 21:44, Chris Casinghino <chris.casinghino AT gmail.com> wrote:
Hi Adam,
Thanks for the quick response. You're certainly right, and I should
have been a little clearer. I'm interested specifically in logical
consistency, and am not concerned about extraction or the fact that
the axiom will get in the way of reduction.
--Chris
> Such an axiom certainly breaks extraction, since it has no natural
> computational interpretation, but perhaps you don't care about extraction.
> It also makes Gallina "computation" highly non-computational, which also
> might not bother you, depending on the application. I don't know if it's
> logically consistent.
Jonas Kaiser
Saarbrücken
Jonas Kaiser
Saarbrücken
- [Coq-Club] Excluded Middle for Type?, Chris Casinghino, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Adam Chlipala, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Chris Casinghino, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Viktor Vafeiadis, 07/02/2013
- Message not available
- Fwd: [Coq-Club] Excluded Middle for Type?, Jonas Kaiser, 07/02/2013
- Re: [Coq-Club] Excluded Middle for Type?, Andrew Cave, 07/02/2013
